Question about the altitude time correction
Old Nov 24, 2013 | 07:58 PM
aqprider's Avatar
Icon2 Question about the altitude time correction
Well, here goes a question for the math gurus...
If I ran 17.7 at 8500 feet above sea level and outside air temperature was 22C°, then what time I would doing with a same setup at sea level (or maybe, at 700feet) with same OAT???
Thanks in advance for who can give me the most precise answer
Old Nov 24, 2013 | 08:32 PM
boostedh22a's Avatar
Default Re: Question about the altitude time correction
These are the altitude corrected tracks that NHRA races at. http://www.nhra.com/competition/altitude.aspx
Denver is the highest altitude track at 5800. So if you went 17.7 there, you'd run 16.6 at sea level. Running 17.7 at 8500ft would roughly be 16.0.
Assuming you are naturally aspirated.
Old Nov 25, 2013 | 05:02 AM
aqprider's Avatar
thanks ))
using wallace racing calculators I got almost the same result
yes, Iīm NA I/E F22A lude
Old Nov 25, 2013 | 04:36 PM
JDMAF's Avatar
Is 8500 ft your adjusted altitude for barametirc pressure??? Theres days up here in montana that we are at 6335 and the adjusted is well above 8000, in the summer time...
Old Nov 25, 2013 | 05:43 PM
aqprider's Avatar
no, I didnīt
dohcsideSi
Aug 17, 2016 05:49 PM
lunatics209
Apr 22, 2007 08:38 AM
b16a27
Feb 27, 2005 01:40 PM
UNDER PRESSURE
Sep 24, 2003 07:28 AM
Reddog
Mar 18, 2003 12:19 AM
