60ft time question?
Old Apr 13, 2007 | 11:59 PM
lunatics209's Avatar
Default 60ft time question?
ok. im driving a 92 full body eg hatch with a nitrous fed ls-vtec motor with a lsd
gs-r tranny, was running on 24's MT. i dyno at 254 horse and 194 torque. i just went to time my car and i ran best et was 12.4 @108 mph. my 60ft was 1.8. do you guys think i can improve my et and 60ft time? or is this the best i can put out.
also i was running on some stock suspensions. front and rear.thanks.
Old Apr 14, 2007 | 12:08 AM
Redline130's Avatar
Default Re: 60ft time question? (lunatics209)
What was your tire pressure on that run? How was the track prepped?
Old Apr 14, 2007 | 12:16 AM
Default Re: 60ft time question? (Redline130)
my tire pressure was 8 psi. the track was prepped pretty well. my first run was at 10-12 psi and i was spinning. that was a 1.9 60ft. so second run i dropped the psi down to 8 and no problem with traction. i was also reving at 6000 rpm only. do you think i should go higher?
Old Apr 14, 2007 | 03:53 AM
boostedcivicsir's Avatar
Mr. Badwrench
24"s with 254 horse, huh, where are you taching through the traps?
maybe 22"s or 23"s?
the 1.8 is great. is it hooking too much? and bogging?
Old Apr 14, 2007 | 09:49 AM
Default Re: 60ft time question? (boostedcivicsir)
yea i think i should be running 22's or 23's. i feel that i can't pull those slicks off my launch. reving at 6000 my rpm drop down when i let go of the clutch. im also running act 4 puck extreme too so i know that clutch is not a prob. or maybe i should just go higher.
Old Apr 14, 2007 | 12:50 PM
fmfkid250's Avatar
there is alot of room for improvement, Launch off of the rev limiter and you will pull 1.7 60'
Vince Barrett went 11.78@114 on 205whp with a 1.57 60'
Old Apr 14, 2007 | 12:54 PM
nonvtecallmotor's Avatar
Are you launching on the spray? With that hp the traps seem to be low.
Old Apr 14, 2007 | 01:11 PM
gtistile's Avatar
Default Re: 60ft time question? (nonvtecallmotor)
some sort of upgraded rear struts with a higher spring rate in the rear will also help... like these other guys have said, launch off the limiter and flip the nitrous on immediatly after you release the clutch in 1st gear that thing will be movin in a hurry
Old Apr 14, 2007 | 01:53 PM
1 2 NV's Avatar
Default Re: 60ft time question? (gtistile)
i agree with that kind of HP the traps are low. id launch at 8k min.
Old Apr 14, 2007 | 04:51 PM
Default Re: 60ft time question? (1 2 NV)
yea, i got the nitrous switch on full throttle so when i let go of the clutch i full throttle and nitrous comes right away. thanks for all the positive replies. really thought i would do a better 60ft.
Old Apr 14, 2007 | 04:53 PM
RaceProfessor's Avatar
7500rpm
Old Apr 16, 2007 | 03:33 PM
christion's Avatar
I'm very interested in the gator axles!! Do you have a telephone number for me to call you!! Let me know asap!! Send your telephone number at my e-mail adress: turbocrx1229@hotmail.com Thanks!!
Old Apr 20, 2007 | 09:35 PM
OnlyHJC's Avatar
Default Re: 60ft time question? (christion)
just practice and try out different techniques.
Old Apr 22, 2007 | 08:38 AM
10secivic's Avatar
Default Re: 60ft time question? (OnlyHJC)
smaller slicks ? what are you reving to when crossing the line, also usually when looking at your dyno graph and finding your power band will tell you where you should launch.
slooogsr
May 22, 2007 08:10 AM
Honda Bull
Nov 22, 2005 07:53 PM
lilcasino
May 4, 2003 04:22 PM
Toda Party
Apr 24, 2003 03:56 PM
HXMan
Jul 10, 2002 01:40 PM
