Why removing the oil control jet ?
Old Nov 24, 2013 | 09:09 AM
kk333's Avatar
Default Why removing the oil control jet ?
Hi there , have a d15b3 we have swapping a d16y8 head on it..
But everyone says that the oil control jet must be removed by vtec heads because it does not need it why must it be removed can u tell ?
Old Nov 24, 2013 | 04:00 PM
motoxxxman's Avatar
Default Re: Why removing the oil control jet ?
with the oil control jet installed, it does not allow enough oil flow to the head for vtec to work. so you need to remove the jet if you are installing a vtec head.
Old Nov 25, 2013 | 07:05 AM
HAZARDOUZ*CD7's Avatar
Had to do it when I did the mini - me swap on my d15b7.
Same goes for the vtec conversion on an F series.
Old Nov 25, 2013 | 08:12 AM
bluehbcivic's Avatar
10 Year Member
because there's one in the vtec head.
Old Nov 27, 2013 | 06:22 AM
kk333's Avatar
Thanks for your posts..
my mechanic says that's not required to remove it what happens when we not removing the jet ?
Old Nov 27, 2013 | 06:27 AM
kyden's Avatar
the rockers won't engage for vtec. not enough oil.
Old Dec 2, 2013 | 04:53 AM
^^^Exactly it won't allow enough oil into the head.
Old Dec 2, 2013 | 07:39 AM
GhostAccord's Avatar
Did you really need to ask the same question twice? Motoxxxman told you why in the very first response.
Just to clarify, The oil control orifice has to be removed from the block in order to allow the appropriate oil pressure to enter the head from the engine block. Otherwise there will not be enough pressure to engage the VTEC rocker assemblies. that is what the control orifice does. it lowers the oil pressure to the head as it is not required on a Non VTEC setup.
Other than that, you would have to run an external oil pressure line from the block to the head.
dfoxengr
Mar 9, 2007 08:34 AM
Del Sol
Jan 23, 2007 02:26 PM
chrisir19
Dec 19, 2003 07:19 PM
nissanpwrds14
Oct 20, 2003 06:42 PM
rock47
Aug 17, 2002 08:45 PM
