Coil shield cracked and CEL now on
Old Nov 22, 2013 | 04:44 PM
jayare05's Avatar
Default Coil shield cracked and CEL now on
As I was replacing my distributor rotor, the coil shield broke and I assumed no harm no foul if I just left it off.. I now have a cel on with code p1381. I've read that even putting the ignition coil shield on backwards can cause a cel to be thrown. Can anyone confirm this?
I took the distributor cap back off to confirm no wires corroded and still all were intact with solid connections and everything seems to be ok..
FYI.. The cars a 99 integra gsr..any help would be awesome
Old Nov 22, 2013 | 11:55 PM
slowcivic2k's Avatar
Default Re: Coil shield cracked and CEL now on
The CYP sensor has a fault. Either a high resistance wire, or the sensor is damaged or defective. Unless you can source another CYP sensor from another distributor, replace the distributor if the resistance checks out.
kumar*
Aug 28, 2007 09:25 AM
LilCivic04
Oct 14, 2005 09:19 AM
bey
Sep 5, 2003 06:34 AM
Krayzielix
Feb 11, 2003 10:10 PM
