Having engine problems...PLEASE HELP!!
Old Nov 21, 2013 | 05:45 PM
Sambatee's Avatar
Default Having engine problems...PLEASE HELP!!
ok im not a honda guy. i'll explian this as good as i can. the honda has a high low idle running between 1000 and 2000 rpm. and when i shift it into 1st and try to take off it bogs down. after afew seconds it starts to gain speed and rpms. it is a manual. so im practically lost other then thinking of the throttle position sensor. HELP....
Old Nov 21, 2013 | 05:50 PM
marcelosm's Avatar
Default Re: Having engine problems...PLEASE HELP!!
My idle problems were caused by a dirty IACV and a flat out broken FITV. You can check those out and see if after a good cleaning it helps. They are also pretty easy to take out on my del sol so it wasn't much of a hassle.
Old Nov 21, 2013 | 06:02 PM
jbpnoman's Avatar
Test your TPS, fix your idle speed and fluctuation (it shouldn't be that high, and it shouldn't fluctuate), and after you're done with that, check your timing.
Old Nov 21, 2013 | 07:25 PM
dseries123's Avatar
Get your tps sensor adjusted and clean your IACV hopefully your car will be ok
Old Nov 24, 2013 | 03:47 PM
Sambatee's Avatar
thanks for the advice guys. today i found a new problem. my engine is now knocking really bad. i think its the rods which is gonna suck like no other
beocop
Jul 2, 2017 05:19 AM
Neomaczen
Honda Civic (2001 - 2005)
Jul 2, 2013 03:04 AM
shady3260
Jul 23, 2010 10:50 PM
b18forlife
10
Sep 19, 2009 03:54 PM
