Starting Wagon Turbo Project RT4WD
Hi All
Fully built
D16A6 Block
Eagle Rods
SRP 75.50 Forged Pistons
NPR PistonRings
ACL Race Bearings (main & Rods)
Stock Ported D16Z6 Head
OEM Headgasket
AEM Camgear trueTime
3 Bar Map Sensor
Turbo Kit:
Custom Ram-Horn Manifold
Holset Hx35 Turbo
Tial 38mm Wastegate
Custom Dumptube
3'' Custom Open Downpipe
Custom Backdoor FMIC
Greddy BOV
3'' Custom Coldside Piping
first step
We want stronger sleeves
Fully built
D16A6 Block
Eagle Rods
NPR PistonRings
OEM Headgasket
3 Bar Map Sensor
Turbo Kit:
Holset Hx35 Turbo
Tial 38mm Wastegate
Custom Dumptube
Greddy BOV
first step
new sleeves
d16 with a view HX35R
Who is Mr Robot?
We have an AWD Element (07, K24) and the pinion flange rotates CW (looking at the front of diff) and I have 0 clue which way the AWD CRV (non k series) rotates.
I was debating putting the AWD B series manual trans behind my built, ITB, GT2871R, LS/VTEC.. but I was going to block off the front axle holes with machined aluminum plugs, get the AWD rear subframe and what not in, a one piece aluminum driveshaft and BOOM... RWD civic with not a lot of work lol
The reason for wanting the AWD EX Element rear diff is that they are an OEM clutch type 2 way LSD.. much better than the open rear diff the B20 AWD CRV came with
Who is Mr Robot?
err wait, i've seen that thread.
I'm trying to find someone that knows the direction the 1st gen b20 awd crv rear diff tuns.
Might have to schlep on over to the CRV forums lol
Who is Mr Robot?
cast iron won't work.. it's too brittle and won't take the heat and pressure
all aftermarket sleeves are ductile iron, big difference
Nice build miss my boosted RT wagon all the time.
as for the Gear ratio of CRV vs civic wagon you can run either combo guys have dont b swaps into wagons and kept there civic rear diff with the CRV trans no issues.
Running with hx35 15 psi,
until now have not had transmission problems
1boostedcivic
Oct 20, 2005 12:18 PM
AEM EMS
