egr valve
Old Nov 20, 2013 | 12:11 PM
cp3accord's Avatar
Default egr valve
I have been dealing with the same problem for almost a year now. My check engine light came on and said insufficient flow. Relating to the egr valve also says 1-5 cylinder's are misfiring most likely in connection to the egr valve. I have replaced the egr valve 3 time and had the ports cleaned out a few times as well in the past few months and put fluids in to clean the carbon build up. but the problem keeps coming up. My check engine light is back on and has the same codes as before. I'm not sure what to do to anymore. Suggestions please!!
Old Nov 20, 2013 | 03:19 PM
EG6 Love's Avatar
Default Re: egr valve
I have only had to clean my EGR port once in 100,000 miles. I run quality fuel and keep my car well maintained.
You may not be clearing the EGR port enough. It's unlikely that the EGR valves are even bad.
Old Nov 20, 2013 | 09:39 PM
holmesnmanny's Avatar
The issue could be in between the egr valve and the exhaust port in the head.
Old Nov 21, 2013 | 05:05 AM
ej7attack's Avatar
could be running rich or O2 sensor carboned up sensing the running condition. if you have thoroughly went through every component pertaining to the egr system, and are certain it is functioning properly, start with giving it a tune up if you haven't already, then check fuel pressure, and o2 sensor conditions.
Old Nov 21, 2013 | 02:22 PM
EG6 Love's Avatar
x2.
swertepinoy
Oct 12, 2009 02:50 PM
burgertime32
Mar 9, 2008 07:46 AM
QUAIJAI
Jan 21, 2005 12:46 PM
Cyber ITR
Nov 21, 2004 06:26 PM
