CHECK ENGINE LIGHT
Old Jan 21, 2005 | 07:21 AM
QUAIJAI's Avatar
Default CHECK ENGINE LIGHT
My 98 Accord's check engine light just came on. The car has roughly 90k miles. I used a hand held tester to test the OBD-II and I received a P1491 code stating EGR valve lift sensor trouble code. Are these tester's reliable? How offen does the EGR valve go out? The dealer is stating that the EGR valve cost $200.00. Is this about right for the Valve? please let me know. Thanks for your help.
Old Jan 21, 2005 | 07:58 AM
CH954's Avatar
Default Re: CHECK ENGINE LIGHT (QUAIJAI)
that happened to a buddy of mine. unbolt yours, clean it out and try it, his had the same code and it was just all clogged up. if that doesnt work i have one from my f23 with 38k miles if you want...
Old Jan 21, 2005 | 08:27 AM
QUAIJAI's Avatar
Default Re: CHECK ENGINE LIGHT (CH954)
CH954,
What is a f23? I did unbolt the ERG valve and the valve didn't look clogged up. What should I clean in the valve? How much do you want for your valve?
Thanks.
Old Jan 21, 2005 | 12:46 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QUAIJAI &raquo;</TD></TR><TR><TD CLASS="quote">How offen does the EGR valve go out? </TD></TR></TABLE>
It's pretty common. Honda has a warranty extension on the EGR systems good for 80000 miles because of the problems.
swertepinoy
Oct 12, 2009 02:50 PM
dr_g
Nov 10, 2008 10:26 AM
airikkCRX
May 18, 2007 09:51 PM
.BigSexy
Jun 18, 2006 10:04 PM
