Cooling System Rebuild(?)
Old Nov 20, 2013 | 07:57 AM
Fork'd's Avatar
Default Cooling System Rebuild(?)
Hello all.
I have a 1998 Civic Sedan DX that over heats pretty badly. So I had this bright idea to redo the cooling system. Fan, thermostat, water pump, and fan switch. This car is in pretty rough shape. I do have further plans for this car.
I know that the water pump will take some serious work to replace but every thing else I can do.
I already have a Skunk 2 Alpha radiator, but I won't put in until everything else is fixed/replaced so that overheating won't damage it.
Any recommendations for parts or suggestions where I should start?
Old Nov 20, 2013 | 08:01 AM
Former User's Avatar
Default Re: Cooling System Rebuild(?)
Before you start replacing parts, have you ruled out a blown head gasket?
Old Nov 20, 2013 | 08:10 AM
Fork'd's Avatar
Blown head gasket?
I'll look into that. I wouldn't have thought that the head gasket could cause over heating.
Thanks for the advice. I'll post an update on if it's blown or not.
EDIT: For a blown Head Gasket, wouldn't there be water in my oil or some kind of smoke/steam coming from the head by chance? Maybe even oil in my coolant?
Old Nov 20, 2013 | 10:27 AM
VeganEJ8's Avatar
You should do a compression test
Zer0_
Mar 23, 2015 07:55 PM
lyzer227
Mar 27, 2008 08:27 PM
lyzer227
Mar 27, 2008 07:50 PM
Bobby808
Apr 27, 2005 11:22 AM
BooSTED IsLANDER
Jan 22, 2004 09:38 AM
