b18b rebuilding want a nice all motor setup
Old Nov 18, 2013 | 02:08 PM
re rex's Avatar
Default b18b rebuilding want a nice all motor setup
Going all motor b series... Need to rebuild motor cause of rings and might as well build something wild with street manners...
Dunno what to expect here or parts to buy, but I wanna keep it on pump gas.
Old Nov 18, 2013 | 02:38 PM
F22Master's Avatar
Default Re: b18b rebuilding want a nice all motor setup
P30 (if staying non-vtec) or ITR (if going vtec) pistons
OEM rings
OEM bearings
OEM oil & water pumps
Your next step is to determine if you want to stay non-vtec, or to buy a B16 or GSR head and convert to vtec.
Old Nov 18, 2013 | 05:22 PM
tavo.760's Avatar
thats right thats what i did to my ls i just added intake manifold port match with the head a set of cams and port match the TB mm i had decent power
Old Nov 18, 2013 | 05:25 PM
10psiLsEf2's Avatar
This is a honest answer that alotta peeps here on the forum will tell you.
Its gonna take alot of money and work to even break 180 whp with a ls block,head combo.
Your best bet for bang for buck is to turbo the ls motor.
Ive had both and nevervwill i try and go na ls again.
Old Nov 19, 2013 | 10:31 AM
re rex's Avatar
Ya well trying to avoid turboing guess ill be looking into a engine swap...
Old Nov 19, 2013 | 12:38 PM
TheShodan's Avatar
Moderator
or swap a VTEC Head onto what you have. Your choices will exponentially expand
Old Nov 19, 2013 | 05:07 PM
re rex's Avatar
I'm wanting to stay all motor to avoid tuning problems seeing as a tuner is 4 hours away
Old Nov 28, 2013 | 05:48 AM
10psiLsEf2's Avatar
No matter na or forced induction. Tuning should be at the top of your list of things to do
Old Nov 30, 2013 | 04:37 PM
blackeg's Avatar
this thread hurts my brain. what i think you are saying is that you want a stock motor with bolt ons so you can use a stock ecu.
the earlier post about not breaking 180whp without a ton of work on an ls is the truth.
no matter if you go vtec or not (which i would recommend) if you want any kind of internal parts you are likely going to need it tuned. id start with that
Old Dec 1, 2013 | 06:30 AM
re rex's Avatar
Just bought a h23 blue top yesterday and I have a s300 here.
j_kevin_ca
Aug 14, 2007 06:38 PM
96civich22
Aug 5, 2004 07:10 PM
Turbo-Honda
Mar 14, 2004 08:35 PM
sleepin91teg
Dec 20, 2003 09:34 PM
yeaaaa its slow
Apr 9, 2003 06:40 PM
