92 civic automatic transmission issues..helpp!
Old Nov 13, 2013 | 10:56 AM
kali.crooks.eg6's Avatar
Default 92 civic automatic transmission issues..helpp!
so I have a 92 civic with automatic transmission that is having problems when going into gear. when I shift to R it goes then I shift to D4 still works but if I try to shift to R again it acts like its in Neutral and wont do anything. I try to shift manually from 1-D4 still nothing car wont go into gear its just revs when I gas it. I have to turn it off and on until it goes away and then itll happen again. it only runs good when you turn it on and drive away once I get to a stop the car acts like its in neutral and I have to turn off and on until it decides to go in gear. am lost checked the tranny fluid bright red no burn smell no cel jumped the cel and no codes tried a different computer and acts the same. what can it possibly be??
Old Nov 13, 2013 | 11:56 AM
Default Re: 92 civic automatic transmission issues..helpp!
****UPDATE TRANSMISSION IS MAKING A GRINDING NOISE AND WONT GO INTO ANY GEARS..
Old Nov 13, 2013 | 12:36 PM
angrysmileyface's Avatar
Drop pan and see how much is on your magnet. Its most likely time to replace this transmission. Otherwise, find a service manual for this car and go through the Tshooting process. In the mean time, search for posts by RonJ about his auto trans and resolutions.
Old Nov 13, 2013 | 02:22 PM
thank you ill check his post and see whats going on thank you. but im still at loss on why it would give out.
Old Nov 13, 2013 | 11:15 PM
apexi_rsx's Avatar
if it is not moving then most likely your trans has been slipping and is finally now has completely went out.... this is what automatic transmissions do when the clutches go out. its a wet style clutch so if one disc goes out they all go at the same time...
civic08
May 27, 2011 01:35 PM
jdmejcivic
41
Apr 6, 2010 07:30 PM
damgon
Transmission & Drivetrain
Aug 20, 2009 10:48 AM
gotdurt
Dec 18, 2006 04:48 PM
BRAGAN
Jun 27, 2006 11:08 AM
