crankshaft flucuation sensor help!!!
i have a 98 ex civic with a 99 gsr swap...im using the obd2a p72 ecu....well im getting the crank flucuation sensor code. when i look at the crank, i see a plug thats not plugged into anything...im curious to where the damn thing plugs into...i want my car running normal again. any help would be greatly appreciated...thanks!!
It plugs into the engine harness. Also you can bypass the sensor.
http://www.ff-squad.com/technet/ckftrick.htm
ok i see it now. the ex harness is a 3 wire, and the gsr is a 2 wire...so can i just get some extra wire and connect the 2 matching wires up and it be good? i believe its white/red and blue/red....im guessing the orange/black is just a ground
Bjm1118
Mar 12, 2019 04:58 AM
