Coolant leak from VTEC solenoid?
Old Nov 10, 2013 | 08:49 PM
DatSlammedek4's Avatar
Default Coolant leak from VTEC solenoid?
Okay so I recently swaped to a d15b7 with a z6 head and a y8 intake mani. Now I used the z6 mani gasket. (Dont ask why) NOW! Im leaking coolant from right under the vtec solenoid or around it. Ive never heard coolant coming from vtec solenoid. Under the solenoid it's dripping. I can see it drip from there. I dont know if it is the manifold or what. Please help.
Old Nov 10, 2013 | 11:58 PM
nebster66's Avatar
Default Re: need help please!!
Sounds like you need to visit a shop cause I don't think I have ever heard of coolant leaking from where your saying (by the VTEC solenoid) so yeah...
Only thing it may be is perhaps the radiator hose is leaking?
Old Nov 11, 2013 | 01:23 AM
HondaPartsHero's Avatar
Technical Hero
Pressure test and see where the leak is
Old Nov 11, 2013 | 08:12 PM
Okay. I fixed one leak. It was the manifold gasket, I bought a new gasket. Now the vtec solenoid is leaking. Yeah I took it off and theres a coolant passage to cool it down. Thanx anyways.
Old Nov 12, 2013 | 05:09 AM
BeatDX's Avatar
New solenoid gasket?
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Old Nov 12, 2013 | 10:27 AM
Former User's Avatar
Default Re: Coolant leak fron VTEC solenoid?
In the future, please create thread titles that summarize your tech question/topic.
"need help please!!" is not adequate.
Thread title edited.
Old Nov 12, 2013 | 10:50 AM
Telecatster's Avatar
Check the temperature sending unit and coolant hose near (under) the distributor.
Old Nov 12, 2013 | 04:13 PM
apexi_rsx's Avatar
cant use the z6 intake manifold gasket on a z6 head when putting a y8/y7 manifold on. the z6 has a square coolant hole and the y7/y8 have a circle coolant hole. I have a y8 manifold on my z6 with a y8 IM gasket and have never had problems with leaks.... I recommend smearing alil rtv on both sides for safe measure and sure seal.....
Old Nov 12, 2013 | 04:46 PM
Thanx guys. I already fixed the manifold leak issue. Im leaking oil from the vtec solenoid really bad. So ima get a gasket. Thanx anyways
Martin Ramsey
Jun 27, 2018 06:17 AM
2000blksi
Feb 14, 2009 03:11 PM
sirrjibbalott
Mar 15, 2006 12:46 PM
Jeffrey9
Nov 27, 2005 12:25 PM
311
Sep 13, 2002 05:31 AM
