Vtec solenoid leak?
Re: Vtec solenoid leak? (neo_)
[b]If it was a head gasket leak i heard there would be alot of bubbles in the oil and the coolant would be lost in the process. And i have hit vtec a couple of times recently when i did not see the leak. i took it to about 8k rpm. is the solenoid leaks going to affect my motor in anyway since i hit vtec with that leak?
thanks guys
thanks guys
Re: Vtec solenoid leak? (sirrjibbalott)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirrjibbalott »</TD></TR><TR><TD CLASS="quote">[b]If it was a head gasket leak i heard there would be alot of bubbles in the oil and the coolant would be lost in the process. And i have hit vtec a couple of times recently when i did not see the leak. i took it to about 8k rpm. is the solenoid leaks going to affect my motor in anyway since i hit vtec with that leak?
thanks guys </TD></TR></TABLE>
Your VTEC system is Oil Dependent and it is very important to have a consistant oil supply/pressure to the VTEC Solenoid.
XkjeldorX
04-18-2005 04:33 PM
