Timing Belt Popped
Old Nov 7, 2013 | 06:31 AM
MyWhiteEJ6's Avatar
Default Timing Belt Popped
About to go on a cruise with friends and right before we get on the highway (1604) my timing belt broke. The car cut off and I tried cranking the engine for a second and then pushed car to the side of the road...
Did I do any damage to the valves?????
Old Nov 7, 2013 | 06:45 AM
ej1995's Avatar
Default Re: Timing Belt Popped
Probably...
Old Nov 7, 2013 | 06:47 AM
MyWhiteEJ6's Avatar
How can I tell for sure without removing the head????????
Old Nov 7, 2013 | 06:48 AM
purgat0ry's Avatar
Honda's aren't non-interference engines.
i.e., your timing gets too far outta wack / snap your belt and it's very likely that you caused your pistons to make sweet sweet metalic love to a valve or two.
Good luck.
p.s. no there isn't really a way to tell if you did / didn't without replacing the tbelt and doing a series of compression tests.
You'll likely have LOW compression on the cyls that were damaged, or NO compression at all.
Old Nov 7, 2013 | 07:00 AM
kyden's Avatar
sometimes you can get lucky. I had some teeth sheer off but the motor was fine.
Old Nov 7, 2013 | 08:55 AM
carlos8's Avatar
The most easy way is to put a new timing belt and do a compression test.
Or maybe even you no need a C.T. if your car start like it have cams or not even start.
Old Nov 9, 2013 | 01:32 PM
MyWhiteEJ6's Avatar
So I removed the valve cover, AC, Alternator, and power steering belts. I tried turning the crank pulley and met some resistance. WTF is going on??
P.S. the cams are not TDC they're way off
Old Nov 9, 2013 | 01:36 PM
slowDB7's Avatar
if your getting resistance rotating by hand, then your piston is hitting some valves
Old Nov 9, 2013 | 01:54 PM
MyWhiteEJ6's Avatar
Yeah I'm going to remove the head tomorrow
Old Nov 9, 2013 | 04:12 PM
Snowman3645's Avatar
did you pull the timing belt all the way out before you tried turning it? pulling the head off is still the preferred way to fix this problem for sure...just a thought.
even if it looks like your valves weren't damaged you need to take them out and check them. they won't always be bent way out of shape. doing a quick valve job will ensure you have compression once it goes back on. check this video out
Old Nov 9, 2013 | 05:39 PM
boostlsveg's Avatar
^sweet vid
Old Nov 10, 2013 | 04:39 PM
MyWhiteEJ6's Avatar
AWESOME video.. I truly appreciate you posting this vid!!
Old Nov 10, 2013 | 06:38 PM
MyWhiteEJ6's Avatar
I replaced the belt and it started right up.. How lucky am I !!!
sd619jef9
18
Aug 25, 2012 10:35 AM
carr
Nov 22, 2006 07:41 AM
RockLee`
Oct 29, 2006 03:43 PM
andlude
Sep 17, 2004 07:09 AM
B18C-RnVA
Mar 14, 2002 06:44 PM
