Welding on to Compressor Housing
I've got a 60 Trim T3 from a T-bird, which has funky inlets and outlet on the compressor that I can't just put a silicon connector on, so I'm thinking of either fabricating some adaptors for myself, which will be a pain, or just welding some pipe straight on to the compressor housing, and choping off the excess metal on the outlet for clearance reasons. Is there any reason I should or shouldn't do the later?
[Modified by johnisenglish, 1:15 PM 10/27/2002]
Go to a muffler shop and ask them for a flange like that one. Then weld a small piece of pipe ilke 3 inches long to the flange and bolt it on. Thats what I would do.
If you want to braze it, you can get an aluminum brazing rod. I'm not sure how much heat it will tolerate, but it should be ok since its on the compressor side of the turbocharger. Brazing will be safer than welding as far as warpage goes. Still, the best option is finding a flange that will bolt up. A flange is what its made to use after all.
