compression test on pulled motor
I know that this was covered in previous threads, but they don't specifically tell me how to. so if anyone can help me find out how to do a compression test with the engine pulled, it would be much appreciated. thanks
thanks for the post. yea but the thing is that guy doesn't have the trans with it anymore. I just dont wana waste money on something that doesn't even work.
won't be fast enough compare to what the starter turns it at you'll leak compression before you get a full stroke
it's not practical compare to the speed(rpm) the starter does it at.
leak down is what i would do, it will show more than a comp test. you can also close all valve in set cly and tape a pc of toilet tissue to side of oil dip stick amd lay over top see if air comes out (bad comp ring) or check for air threw oil cap same way
thanks for the suggestion
DropSide
Apr 18, 2007 06:22 PM
Sinner
Jul 12, 2003 05:54 PM
