compression test on pulled motor
Old Nov 5, 2013 | 01:37 PM
lamb25's Avatar
Default compression test on pulled motor
I know that this was covered in previous threads, but they don't specifically tell me how to. so if anyone can help me find out how to do a compression test with the engine pulled, it would be much appreciated. thanks
Old Nov 5, 2013 | 01:47 PM
B_Swapped93's Avatar
Default Re: compression test on pulled motor
jump the starter with 12V for 3/4 cranks, you'll need the trans too tho(obv) not a short block. at least that's the way I've done it.
Old Nov 5, 2013 | 01:56 PM
lamb25's Avatar
thanks for the post. yea but the thing is that guy doesn't have the trans with it anymore. I just dont wana waste money on something that doesn't even work.
Old Nov 5, 2013 | 02:11 PM
Barf Hat's Avatar
Couldn't you jst turn the crank by hand?
Old Nov 5, 2013 | 02:17 PM
lamb25's Avatar
im not sure but wouldn't that seem difficult? would it get the same readings?
Old Nov 5, 2013 | 02:20 PM
won't be fast enough compare to what the starter turns it at you'll leak compression before you get a full stroke
it's not practical compare to the speed(rpm) the starter does it at.
Old Nov 5, 2013 | 02:23 PM
jdmh22eg2's Avatar
leak down is what i would do, it will show more than a comp test. you can also close all valve in set cly and tape a pc of toilet tissue to side of oil dip stick amd lay over top see if air comes out (bad comp ring) or check for air threw oil cap same way
Old Nov 5, 2013 | 02:25 PM
lamb25's Avatar
Originally Posted by jdmh22eg2
leak down?
would a leak down test be reliable before purchasing?
Old Nov 5, 2013 | 02:36 PM
lamb25's Avatar
thanks for the suggestion
Hidenplanvew
Mar 24, 2014 10:24 AM
DropSide
Apr 18, 2007 06:22 PM
armash
13
Sep 23, 2006 04:51 PM
smallttocs
Mar 29, 2005 10:42 PM
