b20z? i have some questions about it??
i recently bought a b20z and lately ive heard its a bad engine to boost because the sleeves are to thin. i was wondering how it would do all motor or how much it would cost to sleeve it or should i just keep my b18b1 in my ef? and also i was wondering if i could get some more info on the b20z thanks!
B18B1 is decent for boost depending on ware. the pistons are flat enough for adding some boost and the sleeves are not thin like the B20. I would keep the B18B1 and just do a head gasket and slap some boost. You wont be running High boost without a re-sleave. you can safely run about 10lbs on B20. depends on your budget and what your looking to do.
Head work head work don't forget the head work and you'll get some good gains
The B18B1 is a good motor to boost. Low compression is forgiving and it can handle some power on stock sleeves. I would go with ARP head studs if you are boosting the motor. You can run high boost without a re-sleeve though. You can run 100 lbs through a T25 1G turbo, probably blow the turbo to pieces, but it won't be making any power after about 18 lbs and will only cause damage to itself. With that said, at 18 lbs you probably will be seeing 250 whp or so. But if you went with a larger turbo, like the T3/T4 57 trim Garret turbo I have, 18 PSI will see 450 HP or so. Which can definitely cause some bottom end damage. Still probably safe on stock sleeves though.
And the B20Z head is a good high flowing head. Works a lot like a VTEC head (flow wise). It's a great motor, would I swap the B18B1 for it, I don't know. The turbo will be more fun than an all-motor build if you are setting aside a decent budget. I'd turbo the B18B1 and skip the B20Z.
PSI is 100% dependant on the turbo, therefore should not be considered when determining what an engine can handle. Torque is what damages engines, torque is also directly related to horsepower. With this said, horsepower should be used when determining what is safe. Not pounds per square inch.
PSI means nothing. It's horsepower that matters.
Do it right or do it twice. Take a chance on Ebay stuff if you want to.
Do a compression test on that engine before you do anything. I don't think I'd be comfortable boosting anything with that many miles on it.
You can't use a B-series transmission on a D-series engine without an adapter.
PSI means nothing. Get past that and stop listening to all these dumbasses that keep telling you "xx PSI should be safe". If you ever read anywhere that someone says that you should instantly know that they don't know ****.
Fuel and airflow (CFM) to get you to a desired horsepower, and a good tune to make it all work flawlessly is what gets you to your goal. PSI is a byproduct.
200-220 horsepower is about all I'd try to push through a stock block. 180 would be safer unless you plan on building the block then the sky's the limit.
again, its not about psi. its about how much horse power the engine can handle regardless of what psi the turbo puts out
and alot of people would suggest that stock d-series engines are safe until about 200 whp
that safety line may be lower if you have high mileage or problems with the oil system
for the last time (and i hope you understand it this time)
your psi will have NOTHING to do with how much horse power you make
why?
because each turbo flows differently at different rpms
so psi is indeed a byproduct of what turbo you have, and what HP your engine puts out
why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turboDerrick »</TD></TR><TR><TD CLASS="quote">I wasn't plannin on spending that much , but one thing after another kept comming up broke or old and worn. .... There's alot more to it than you think.</TD></TR></TABLE>
words of wisdom right here. this man has been through it first hand, I can tell.
to the OP: psi doesn't matter. you can't just say "I want to run 20 psi" and work around it. you need to pick a horsepower goal, and shoot for that.
good luck running 20 psi on pump gas anyhow unless you drop your static compression ratio pretty low.
so if you have a bullet proof block and you can run 30lbs of boost and you can run 10 on another engine. the more boost as long as your engine is built for it 30lbs would create more HP. that's why people use Boost gauges not HP gauges.
I'm not understanding your theory on this.
to me your theory is like saying me running in a dead sprint for a quarter mile has nothing to do with the amount of oxygen I can intake but just about my muscle strength.
and my reference of safely running 10lbs was directed to just the B's not every engine.
True but but OP's question wasn't about HP he was asking about boost on a B20 and the sleeves. the condition of the engine is what would better determine the amount of Boost/HP he can handle. I'm not quite sure I believe Boost is a byproduct of HP. it's more l like HP is a byproduct of Boost. and 10lbs is 10lbs. saying 10lbs of boost is different depending on where its from makes no sense. if 10lbs from one turbo is greater then 10lbs from another sounds like someone isn't running 10lbs. stress on the turbo is a factor though a tiny turbo is working harder to put out that 10 compared to a big one.
Here's a quick tip. It has a lot to do with surface area. Imagine a water hose. You leave it open and it's a large hole. You are only getting 5 PSI of water coming out of it. You stick your thumb in front of it, you are now getting 20 PSI of water. The pressure increased. In order for the big open hole to have 20 PSI you would have to turn the hose up more. Therefore it is using much more water to get up to 20 PSI because there is a larger hole. Same thing with a motor, except instead of how much water, it is how much horse power.
Nex thing, you build a block for the HP, not PSI. 30 PSI through a T25 turbo might get 300 HP. 30 PSI through a 72mm Turbo (like the big supras use) is 1000 HP. You are telling me 30 PSI should be the same for those turbos.
You didn't read those quotes very well, 10 PSI has nothing to do with how much power the motor makes. That metaphore of yours was also horrible. Your respiratory system is basically one giant muscle group. I guess you must hold your breathe when you run a sprint.
Your analogy on the head is wrong. The non vtec heads are some of the worst flowing heads with exception of the P8R which flows close to a B16.
Getting back to the OP's question, As a owner of a few b20's its the cylinder pressure that will crack a sleeve. Theres plenty of B20's on boost that work fine. Its all in the tune so theres no detonation.
Detonation in addition to cylinder pressure will crack a sleeve. The B20 sleeves are a siamese design which is different than the B18B. The B18B also has more CR (9.8) then any of the B20 blocks.
Theres a few that have pushed B20 stock blocks/bottom ends past the 300whp line with success but most of the time 300 at the crank is the limit.
If you already have a B18b, I would just boost that. Flow rates go out the window when your forcing air into engine.
google B20 P8R and youll see the HT thread with more on the B20 block
If I was wrong in what I said, I am sorry for spreading bad information. But I may have actually just been a tad confused and got something mixed up.
B20's do not have thin sleeves. They crack between the sleeves when boosted. They actually look thicker than B18 sleeves.
Psi has nothing to do with HP. Saying a given engine can handle X amount of boost is wrong.
Having said that what you can and cant do depends on your goal. If your goal is 270-280whp buy the appropriate sized turbo and by all means turbo the B20Z. If you want more power than that I would go with a B18.
The other heads are the P75 heads on the B18/B20b/z that are normal for those blocks. Finding a P8R is like finding a unicorn at this point in time since they stopped being made back in the late 90's
Thanks. I guess he just had a P8R head that he was using on the B20 block. I just connected the dots and I was wrong. Guess I get that for assuming.
by the way guys quick question non related to the b20z is anyone aware of a site or a place around indiana that sells peformance parts like pistons rods etc. thx and whats a good brand ?
keep in mind turbo size & how much boost your running. More boost means IAT will probably hotter & therefore have greater chance of detonation.
B20 turbo is fine. IMHO, this is how i would seperate the limits of the b20 stock sleeve
1) stock block 100%
a) small size turbo (evo 16g)
12-15psi 250ish whp pump gas
18-24psi 280-330ish whp e85
b) medium size turbo (50-55trim)
10-12psi 250-270whp pump gas
14-16psi 300-350whp e85
2) b20 with css block modification (rods & piston, stock head)
medium size turbo (50-55trim) = 400whp @ +18-20psi or so ...pump or e85
larger size turbo (+60trim) = 500whp (really depends a lot of stuff) +25psi psi e85
these are pretty medicore guesstimations ment to provide rough idea. Don't make the mistake of using some exceptional builds as the bench mark to go by.
GL
yeah the b20 having "thin" walls is a bunch of crap. its just designed differently. i love my jdm b20b in my 93 si hatch. really fun engine. they respond better to bolt ons then any d series. if tuned, all the better.
a b20 with a vtec head is a really fun ride. i decided i really didnt need to turbo mine because it makes good power already. but some people have an addiction for speed and need to turbo lol. i just wanted a reliable, quick, fun to drive, car.
So do you guys recommend resleeving the block? Block girdle, or a block gaurd? Just because I have a b20z and want boost later kn down the line. IF I do boost later one its gonna be around 6-8psi but the turbo might be pretty decent size "have one off my mustang" unless I come around a better deal.
I have a boosted b20 vtec that's been going strong for about 2 years. Stock bottom end never touched. It puts down over 350whp on 11 psi. Get yourself a good tuner and you'll be fine. I should add I've had the block for about 6 years it was b20 with boost,then b20vtec supercharged for a few years then all motor. Now it's boosted
