Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2007 accord sedan 2.4l
Old Nov 4, 2013 | 08:19 PM
leftie's Avatar
Default 2007 accord sedan 2.4l
Hi,
I have 158,000km on our accord. When should I do the timing belt. Any other info would be greatly appreciated.
Thanks
Old Nov 5, 2013 | 04:57 AM
johnsc2235's Avatar
You have a timing chain and as long as you have kept up with good oil changes there is no need to replace the chain.
Old Dec 12, 2013 | 03:13 PM
hughmcaper's Avatar
Default Re: 2007 accord sedan 2.4l
Really? No need to repave the timing chain? A dealer told me it had to be done at 100,000kms.
Old Dec 13, 2013 | 02:42 PM
Lost Again's Avatar
Again, the four cyl (Canada I know does - pretty sure UK as well, I see you are using km not miles) have a chain and only will need to be replaced if and when it stretches too much - and again, regular/quality oil changes - level checks will help extend the time.
Old Dec 15, 2013 | 04:49 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Although the 4 cylinder has a timing chain that doesn't require replacement under normal circumstances, there is still a drive belt that should be changed at recommended service intervals.
Old Dec 16, 2013 | 05:01 AM
hughmcaper's Avatar
Default Re: 2007 Accord Ssedan 2.4L 24valve, DOHC iVtec
Thanks. Actually, this is a USA car. Registered in miles. I do regular oil changes every 10,000m with full synthetic oil. I don't know if it has a chain or belt. But, drive belt shold be replaced at 60,000miles?
Old Dec 16, 2013 | 12:40 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
For the drive belt, check the condition of the drive belt (i.e., look at the auto-tensioner gauge position if it is within range (there is a pointer and gauge range on the auto-tensioner), inspect belt for obvious damage; a few cracks (rib side of belt) is not a big concern, only if a lot of cracking or chunks gone then it is a concern). Replace belt if gauge position not within range, or belt damage. Otherwise, under normal conditions, drive belt should be good for at least 105,000 miles. I like to change it a little before or at about 105,000 miles.
Old Dec 23, 2013 | 07:46 AM
hughmcaper's Avatar
Thanks. I will check all the things you mentioned.
cavaliertx
Dec 13, 2016 09:02 AM
greened3
Sep 8, 2013 05:12 AM
pushintealhondas
Feb 16, 2008 07:29 AM
Two400
Jan 22, 2008 04:10 PM
04accord94civic
Apr 27, 2005 04:53 AM
