Pilot rear main seal leak transmission removal
Have an 07 Pilot. Rear Main starting to leak. Has anyone removed transmission without removing the motor? Haynes manual saying to remove both engine and trans as a unit then break apart but I don't want to do that. Can tranny be dropped separately? Is there clearance to get it out?
well with out some good support that will hold the engine on the side , it will be really hard , u will have to pull the k frame out and also all mounts but the pass side engine mount ,
how difficult is it and what is the safest way to remove the rear engine mount to install energy mou
Lei Siew Long
Aug 30, 2001 01:13 PM
