Dies When Put in Gear
Hi All,
I have a 2000 Accord LX. My daughter's car. When you put it in reverse, drive or any other gear it lurches and dies. It felt like the torque converter was staying locked up. I unplugged the TCC/Shift A solenoid and it went in gear without dying. Plugged that back in and unplugged the B and C solenoids one at a time. Dies with B unplugged, but not with C. I pulled C and it's reading about 15 ohms (within spec). Put power to it and it clicks. I was really hoping it would be Mr C, but apparently it's not.
Any other ideas?
Thanks in advance.
Any other ideas?
Thanks in advance.
P0753 Problem in Shift Solenoid Valve A Circuit
P1738 Problem in 2nd Clutch Pressure Switch Circuit
P1753 Problem in Torque Converter Clutch Solenoid Valve Circuit
Check the wiring harness and ground cables for the transmission.
failcookie
Aug 2, 2016 09:50 PM
