How to tell if your car was an automatic?
Old Oct 29, 2013 | 09:18 PM
ICeDoUt's Avatar
Default How to tell if your car was an automatic?
Got back into a honda and figured i'd share (and the kit is already stripped off);
The next day:
I'm curious as how to tell if your car used to be an auto. I was told by the previous owner that it was, but he also thought this car was a 1997. The title says 1996 and the car is midori green, which was only produced in 1996 if i recall.
It does have an automatic cluster. but everything else seems to be perfect. the clutch master cylinder looks like it was never touched since 1996. The pedal assembly has the yellow line markings on it, no excessive cutting was done. and the shifter hole looks the same as a manual (not sure if it would be a different size anyway).
Anyone with any ideas on how to tell if it was automatic?
Old Oct 29, 2013 | 09:31 PM
TypeRfit's Avatar
RESIDENT
Default Re: How to tell if your car was an automatic?
Take off the center console, if it was an auto you should have a big hole or repaired area where the auto shifter box used to be. You can also tell where the 5 speed shift linkages bolt up inside the car, if it was a factory 5 speed the nuts will be factory welded in, if it was a factory auto car then the 5 speed linkages will be bolted up with a nut/bolt combo.
EDIT* 90% of auto to manual swaps also use a conversion mount on the tranny.
Old Oct 30, 2013 | 01:09 AM
HondaPartsHero's Avatar
Technical Hero
Your VIN will tell you
https://honda-tech.com/vindecoder.php
Old Oct 30, 2013 | 05:05 AM
94EG8's Avatar
Seagull Management
Not the case with a '96 - '00 Civic, you simply use the upper transmission mount and bracket from a '96 - '00 5 speed civic. Auto to manual swap is a 100% bolt on affair in these cars. '92 - '95 civics/'94 - '01 Integras require the auto to manual mount or cutting and welding.
Old Oct 30, 2013 | 07:55 AM
TypeRfit's Avatar
RESIDENT
Huh, did not know that. Thanks
Old Oct 30, 2013 | 08:31 AM
jdmh22eg2's Avatar
^ to add to this above
92-95 eg auto/man swap has its OWN mount
94-01 dc auto/man swap has its OWN mount
ask me i know
Old Oct 30, 2013 | 09:46 AM
vitamin_c95's Avatar
do the Eks have that plug under the center console where the auto shifter/neutral safety switch used to plug in like on the EG civics? I converted my EG an have that connector still in there
clockwork675
Audio / Security / Video
Feb 28, 2011 07:27 PM
ramonjones16
Jul 17, 2009 02:57 PM
pinoyboy204
Dec 18, 2006 11:14 AM
jdmekB18C
Jun 4, 2004 11:30 PM
17secondcivic
Mar 21, 2002 08:07 PM
