New Battery-starter spins-no engine crank
Old Oct 28, 2013 | 09:10 AM
kimbothegiant's Avatar
Default New Battery-starter spins-no engine crank
Hello,
Before replacing my battery, the Del Sol electrical items were running slow, i.e. the wipers at first, then digital clock went blank, than the speedometer and tach bounced to zero and back to running speed before hitting and staying on zero till I parked and shut the engine down. No power after that. I figured alternator or battery. Took battery to AutoZone, they recharged the battery to 12.7v and analyzed it with a dead cell. I replaced the battery then turned the key. I got one second of engine crank and then just a spin sound. I assume the starter is spinning. No engine crank.
Any ideas what to look for?
Thanks!
Old Oct 28, 2013 | 09:17 AM
pityocamptes's Avatar
Default Re: New Battery-starter spins-no engine crank
Sounds like the solenoid crapped out... or the connections are not clean?
Old Oct 28, 2013 | 06:04 PM
Okay, any idea how to check the solenoid? Thanks
Old Oct 28, 2013 | 07:14 PM
Former User's Avatar
Have you inspected the teeth on the flywheel and starter?
Have you cleaned and tightened the transmission and battery ground connections?
Old Oct 28, 2013 | 09:22 PM
crazyhouse2011's Avatar
Could be four things:
1. Broken starter teeth.
2. Broken flywheel teeth
3. Bad starter solenoid.
Old Oct 28, 2013 | 11:37 PM
pelayo114's Avatar
Are you sure the starter is spinning?
Its possible the bendix is spinning in place and just not extending.
Old Nov 11, 2013 | 01:21 PM
Okay, sorry for not responding earlier. The starter for some reason now cranks the engine. I charged the battery to eliminate low voltage as a problem with the new battery. I bought a KD calibrated ignition tester and checked all spark plug wires. All showed spark. When you turn the start key, sometimes the engine sounds like it wants to fire for the initial first second and then just continues to crank. Thanks
NightHawk92
Jan 9, 2015 08:06 AM
mysticstylezrx8
24
Apr 14, 2011 09:40 AM
dude9571
Feb 12, 2006 08:03 PM
hans stoner
Nov 2, 2004 01:39 PM
CivicBoi
11
May 27, 2002 11:30 AM
