mini me p28 - how pin stock ecu plug for vtec?
so im doing a mini me with a p28 and i was wondering how to pin the stock ecu plug for vtec? i have a spare intagra harness but i cant find any pins on it that look like the right one to slide into the ecu plug.
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/faq-d15-sohc-vtec-mini-me-massive-write-up-56k-goodbye-554053/
Look at step 6. You don't need to replace your harness.
i understand that, but at a6 and d4 i dont have any pins to pin the stock plug, i was wondering where i can find some locally or if i could use any of the teg motor harness
http://www.hamotorsports.com/ecu-plugs-pins.html
You should be able to clip the proper size from your extra motor harness and solder new wires to them, or you can order a pack of 5 from HAMS at the link I just gave you. Your local dealership might have them, but I make no promises there. I doubt most parts stores would carry them.
meccA's eg6
Jul 17, 2004 09:21 PM
