Re-Tap Engine Mount Threads
I have a b18b1 in my CX 96' hatch, and the two top bolts broke off on the driver side engine mount. After I drill them out, I was wondering which method you guys would say would be the strongest for this situation. Helicoil, Time Sert, or Drill/Tap for 1 size up (M10x1.5). I've done research, but most of the threads I've found are a little outdated, just wanted some more recent opinions. Thank you
if you can and have access to timr serts do that. we use them at chevy for 3.1/3.4 when doing intake mani gaskets as there are a few known threads whr. doing that job that like to pull out. hands down 100x stronger than a helicoil
Yes all 3 holes blown out threads on driver side mount smashing every day for last 2 years or so.
With hasport mounts
Hondas dont normally have 500lbs of torque
With hasport mounts
With hasport mounts
With hasport mounts
you cant drill through the engine mount its very hard metal
dont know what else you want to hear
you have 3 options helicoil or timecert or new block not that complicated
