H22a gas?
Old Oct 25, 2013 | 06:03 AM
Emeraldbomber's Avatar
Default H22a gas?
Hello I am getting near the end of my h22a swap in my ej1. I started doing this swap early because my d series tranny finally gave way. Well when it gave way I had just filled up on 87 octane. So I have a full gas tank on 87. I know the h22a's run off of 91 premium or higher. Is my only option to siphon the gas out? Or could I run it with an octane booster of some sort? I don't have the knock sensor wired up because I'm using my chipped p28. Is it going to knock like crazy?
Any insight is much appreciated.
Old Oct 25, 2013 | 05:30 PM
No suggestions huh?
Old Oct 26, 2013 | 06:03 AM
yungmulacrx's Avatar
Default Re: H22a gas?
How long has it been sitting? Hook up the fuel pump and let it pump out is what i would do..
Old Oct 26, 2013 | 07:58 AM
You mean like unhook the line and prime the pump and drain it that way?
I know they make siphon pumps. Is that something you could get at a local automotive store?
Old Oct 26, 2013 | 09:36 AM
Yes the fuel line off of the fuel rail or the fuel return line.. Your local automotive store should have a siphon pump if thats the route you choose..
Old Oct 26, 2013 | 11:36 AM
kingofbattle909's Avatar
shell v-power+chevron techron=vtak gas yo!
Old Oct 28, 2013 | 08:10 AM
I'm just going to get ahold of a siphon pump lol. I don't wanna take chances.
Old Nov 12, 2013 | 08:54 AM
rsmatti's Avatar
You can just pump it out, I'd say run it but don't beat on the motor (past 4K). You should be OK.
Old Nov 12, 2013 | 02:00 PM
Sonin Fury's Avatar
Depends mostly on your tune. You can run 87 on a stock tune and you will not damage anything, but doing it repeatedly will definitely hinder performance.
Id drive it a little bit, avoid 7K rpm, and then once its about half a tank, fill with premium and go my way.
nick77538
Motorcycles
Jul 7, 2017 08:59 AM
dephtone
24
May 17, 2011 05:19 AM
slvrslepr
Aug 20, 2008 06:07 PM
likwidchz
Apr 6, 2008 09:36 AM
liquid51
Nov 2, 2003 06:41 AM
