leaking vtec gasket after a few days...why,how?
Old Oct 24, 2013 | 11:19 PM
supertace91's Avatar
Default leaking vtec gasket after a few days...why,how?
I just replaced the vtec gasket and it started to leak after a couple of days. I put some oil on the rubber gasket like a oil filtergasket. Do i need to buy a new gasket and put it "dry" or do you use a bit of gasket maker?
Old Oct 25, 2013 | 05:52 AM
Former User's Avatar
Default Re: leaking vtec gasket after a few days...why,how?
Seal it with HondaBond.
Old Oct 25, 2013 | 07:26 AM
TripleLude's Avatar
I had that issue too.
Pull it back off and lap the sealing surface with a sanding block and 400 grit sand paper. Then put it back together after cleaning. Use a little bit of high temp RTV or Hondabond on the sealing surface.
Old Oct 26, 2013 | 12:56 AM
will try
airikkCRX
Jan 25, 2024 03:11 PM
Golden Eagle
May 24, 2012 11:25 AM
Rok_Stok
20
Feb 18, 2009 08:34 AM
Btothe3rdDegree
Aug 20, 2003 06:26 PM
brexracer
Mar 27, 2002 04:40 PM
