Gsr turbo swap
Old Oct 24, 2013 | 09:08 PM
DaOnE51T's Avatar
Default Gsr turbo swap
I'm in the process of swapping in a obd2 turbo gsr in my eg. I'm using the obd1 engine harness on an obd2 motor. Ill be using a obd 1-2 jumper harness for the dizzy, new obd1 plug and play injectors and swapping my alternator plug to the obd2 plug. Could i run a chipped p28 with the stock gsr manifold. Do i leave the o2 plug open? Is there anything I'm missing other than wiring up vtec?
Old Oct 24, 2013 | 09:47 PM
turbohatch96y7's Avatar
Default Re: Gsr turbo swap
You need to run your 02 sensor unless you have the chip set for closed loop. the wiring is simple for the 02 sensor if for some reason you don't have the right harness.
and I think you need to do the ckf bypass im not exactly sure.
You don't plan on driving the car on a basemap do you.?
Check out http://ff-squad.com/technet/ if you need more wiring help.
Old Oct 25, 2013 | 05:55 AM
DaOnE51T's Avatar
I plan on getting it tuned right away.
DaOnE51T
Oct 24, 2013 09:07 PM
jdm_integra_gsr
Sep 8, 2009 06:20 PM
dorikingts
11
Oct 26, 2005 10:30 AM
jaydmegsix
Jul 22, 2005 08:56 AM
Phoenix GSR
Mar 11, 2002 03:45 AM
