Gsr turbo swap
Gsr turbo swap
I'm in the process of swapping in a obd2 turbo gsr in my eg. I'm using the obd1 engine harness on an obd2 motor. Ill be using a obd 1-2 jumper harness for the dizzy, new obd1 plug and play injectors and swapping my alternator plug to the obd2 plug. Could i run a chipped p28 with the stock gsr manifold. Do i leave the o2 plug open? Is there anything I'm missing other than wiring up vtec?
Re: Gsr turbo swap
You need to run your 02 sensor unless you have the chip set for closed loop. the wiring is simple for the 02 sensor if for some reason you don't have the right harness.
and I think you need to do the ckf bypass im not exactly sure.
You don't plan on driving the car on a basemap do you.?
Check out http://ff-squad.com/technet/ if you need more wiring help.
