ac compressor bracket motor mount 96-00
so i bought this http://www.energysuspensionparts.com...p?prod=16.1105
the ac compressor bracket motor mount that is known to break a lot on these cars was broken on mine
see the rubber insert with the 'm' on it? i cannot remove that from the metal bracket
also what about the other piece that is bolted on with the 19 mm nut
@kyden: that makes much more sense, i see how the es inserts are designed to fit around the oem mounts
@triplelude: that looks like a good bushing to me. nice one
i have 2 questions
1) should i get a new oem mount/bracket to put my new energy suspension inserts around?
2) where is it important to put lube? (not just on this one, but all five) i don't want any squeaking
i have 2 questions
