B18B1 - Removing cam gears?
Old Oct 23, 2013 | 03:31 PM
Tram's Avatar
Default B18B1 - Removing cam gears?
Is there a magic trick I'm missing?
I'm trying to pull my head to swap the gasket and I'm looking at trying to get the cam gears off..
What's the magic trick?
Old Oct 23, 2013 | 03:35 PM
slowDB7's Avatar
Default Re: B18B1 - Removing cam gears?
did you remove the caps that hold down the cams?
Old Oct 23, 2013 | 03:43 PM
Tram's Avatar
No, not yet..
I'm wondering if I actually need to take the gears off the cam for what I'm doing?
I'm not at home and can't remember the exact setup. Do the gears even need to come off?
Old Oct 23, 2013 | 03:48 PM
slowDB7's Avatar
the gears can stay on the cams, no need the remove them unless your putting on some adjustable gears
Tram's Avatar
Excellent.. I'll leave them on then.
Old Oct 23, 2013 | 05:42 PM
B_Swapped93's Avatar
odd thread....but if you tried removing them with the timing belt still on that would make it rather difficult.
Old Oct 24, 2013 | 01:52 PM
IN VTEC's Avatar
If you leave the gears on when removing the cams, the timing belt cover behind the gears has to be removed with the cams/cam gears assembly. It's just one 10mm bolt.
And don't forget the cover when you re-assemble...or at worst...nothing bad will happen. It's very anti-climatic so don't do it.
You also have the option of cutting the rear timing belt cover to allow the cams to come out without removing the cover. Adverse effects of doing this: more anti-climaticness.
Old Oct 25, 2013 | 04:52 AM
kyden's Avatar
negative. the non-vtec motor doesn't have this. only the vtec motors you have to remove the rear cover.
Old Oct 26, 2013 | 06:04 PM
IN VTEC's Avatar
Well, ****. Piece of cake then.
mouab18c1
32
Aug 3, 2011 06:00 PM
b20beast83
Sep 2, 2008 04:21 AM
JDM00SI
Feb 11, 2005 10:34 AM
shingles
Dec 24, 2001 04:45 AM
