flywheel swap
Old Oct 22, 2013 | 09:54 PM
jdmjunkie2012's Avatar
Icon2 flywheel swap
Okay hondatech members I got a situation with my flywheel
I have a b16a3 and I swap my flywheel with another b series one and now when
I go to crank the motor the starter sounds like its grinding like it not fitting in the teeth
Of the flywheel I need help if anyone know.....thanks alot..and yes starter
Works fine got it checked
Old Oct 23, 2013 | 02:43 AM
Freemananana's Avatar
Default Re: flywheel swap
I'm not sure if the flywheel was suppose to match the motor in any way. But the scraping could be the throw out bearing. Did you get it torqued to spec? The basics like that?
Old Oct 23, 2013 | 03:10 AM
Yea the bolt are torqued the motor dosent turn when I turn the key all you hear is the starter but the starter aint turning the engine
Old Oct 23, 2013 | 04:12 AM
So the motor doesn't turn but the starter does? If that's true either your flywheel isn't even touching the starter, your starter is too weak to move the motor and needs to be replaced, or your engine is seized. It is probably a wire that's not hooked up correctly or something simple though.
Old Oct 23, 2013 | 06:08 AM
The starter is good I think that I need to align the starter to flywheel im
Not sure ever since I change that fly wheel and clutch its sounds like
It want to turn the flywheel but the teeth dont enter the flywheel pattern
Old Oct 23, 2013 | 06:51 AM
There is no alignment for the starter to flywheel. It either fits or it doesn't. Its a cog. The teeth mesh together. That's all. If the teeth aren't in the flywheel that means the starter isn't bolted all the way down.
Old Oct 23, 2013 | 02:12 PM
do u know if all b series flywheels are interchangable i think they are then it should work i dont know im gonna have to remove my tranny to see if itd the same *** my old one damn another mission lol
Old Oct 23, 2013 | 03:24 PM
jdmjunkieXL's Avatar
Nice username thats original
Old Oct 23, 2013 | 05:08 PM
Thanks I got the problem solved it was ground its cuz my tranny was painted
Old Oct 24, 2013 | 03:01 AM
I WAS RIGHT!
Guess I should have gone with the generic, "Check your grounds" first.
wakaranai
17
Sep 14, 2016 07:02 PM
b16ej8jdm
Apr 3, 2010 11:41 PM
Andyb22g
Nov 22, 2004 03:30 PM
MrBui
Dec 23, 2002 10:29 AM
lilcasino
Aug 4, 2002 08:25 AM
