Upstream Oxygen Sensor 1998 Civic DIY
Old Oct 22, 2013 | 09:40 PM
SDPGreen's Avatar
Default Upstream Oxygen Sensor 1998 Civic DIY
I'm surprised I couldn't find any posts about this for my 1998 Civic - maybe I'm not searching right...
I need to change out my upstream (in manifold) O2 Sensor.
3 questions:
Can I use an open wrench to get the old one out, or do I need to buy one of those specific slotted offset wrenches?
When searching to buy the sensor, is there a keyword I should use to make sure I'm getting the upstream / manifold sensor, and not the 2nd one?
Any tips on where to buy a decent sensor, or ones to avoid?
Thanks.
Old Oct 22, 2013 | 09:56 PM
SDPGreen's Avatar
Default Re: Upstream Oxygen Sensor 1998 Civic DIY
One more question:
I'm only getting a reading that my upstream sensor (Bank 1, Sensor 1). Should I go ahead and replace the downstream sensor too, or just wait for it it fail?
1998 Civic, 153k miles.
Old Oct 22, 2013 | 10:30 PM
SDPGreen's Avatar
Update:
Only question now is if I need to buy the special wrench, or can I use a standard open wrench?
I'm buying these on Amazon for about $32 ea.
Upstream: Bosch 13249 Oxygen Sensor, OE Type Fitment
Downstream: Bosch 13007 Oxygen Sensor, OE Type Fitment
Old Oct 22, 2013 | 11:02 PM
SDPGreen's Avatar
Update II
For upstream sensor I found a "Herko HK-336-24-336" on eBay for $16.90, free shipping; couldn't pass it up.
Going to cut the wires & use a deep socket to get the old sensor out.
Going to wait for the downstream sensor to fail before replacing.
SDPGreen's Avatar
Update II
Old Oct 23, 2013 | 01:02 AM
HondaPartsHero's Avatar
Technical Hero
Should have got a Denso those other two sensors are gonna last about a year if you're lucky. Honestly I'd use the 02 socket, open wrench could strip it and then you're screwed.
Old Oct 23, 2013 | 05:07 AM
Lizardslap's Avatar
I bought that sensor from ebay it lasted almost a month worth the extra money for the denso like 33ish like hondapartshero said
and your gonna find that those sensors are really in there
Old Oct 23, 2013 | 08:14 AM
SDPGreen's Avatar
Thanks for the replies. I'll bet you're right on both counts: If I wasn't so impatient, I probably would of taken your advice. I'm committed now though!
Will try cutting the wires & using a deep socket, not an open wrench, & will cross fingers that I get over a year out of the sensor.
Old Oct 29, 2013 | 12:55 PM
SDPGreen's Avatar
Final Update:
Cut wires & used a 7/8" box wrench; sensor actually wasn't hard to remove at all. Engine was warm, and had sprayed w/ PB Blaster a few times the prior 2 days.
CEL went away after jumping blue connector. Now just hoping this cheap sensor lasts awhile.
I suppose that will close this thread.
Old Oct 29, 2013 | 01:51 PM
Telecatster's Avatar
You can rent (free) a slotted socket designed for o2 sensors at Autozone. You should have bought Denso (oem) http://www.jcwhitney.com/pn/c10479p2...64d894y1998g43
Old Nov 4, 2013 | 08:41 AM
SDPGreen's Avatar
Good tip about Autozone & socket. I'm starting to like that store.
Copy the comment about Denso. Hoping I'll be lucky; so far so good.
Old Mar 9, 2015 | 09:53 PM
SDPGreen's Avatar
UPDATE:
The Herko sensor lasted just under a year and I replaced it in October last year (2014) with a Denso for $40 from Parts Geek (details below).
I the Herko's it's POSSIBLE defense, my radiator has a slow leak and coolant gets blown on the engine...
(I'm hoping to replace the radiator this week.)
1998 Honda Civic Denso Oxygen Sensor - Upstream
Denso 234-4099
Old Mar 10, 2015 | 12:03 AM
NotARaCist's Avatar
I never narc'd on nobody!
That
uh
...wat?
Your radiator leak blah blah thing makes absolutely zero sense, especially in relation to an O2 sensor.
skateboard_ej8
Apr 5, 2011 09:21 AM
joelkriner
Aug 12, 2008 08:32 AM
TurboEM1
Jun 16, 2005 02:22 PM
