EK B20 with d16 compressor hmmmmm
Old Oct 22, 2013 | 07:37 AM
sleepyaccord96's Avatar
Default EK B20 with d16 compressor hmmmmm
ok i put a b20b4 in our 96 hatchback. I was told i could use a p30 b16 ac bracket and i did that. Houston we got a problem. The bracket fits the b20 and yes the compressor is bollted to the bracket but with only 2 bolts, and it happens to be the 2 bolts closest to the drivers side so ya know what i am gonna say next. When i put the ac belt on everything was fine until it was time to lock down the idler i notice a 1/2mm maybe a 1mm gap occurring between the compressor and the bracket. This is not cool with me...
So, Does anyone know what compressor bracket i can use that will allow me to use the d16y7 original ac compressor bolted to the b20 but have more than 2 lousy bolts holding it on. I have seen some people say just use a crv one but also see people say it is the same as the p30 bracket.
TIA and hopefully someone knows which bracket i should be using. I am willing to trade this damn p30 bracket for the one i need.
Brett
Old Oct 22, 2013 | 07:53 AM
HondaPartsHero's Avatar
Technical Hero
Default Re: EK B20 with d16 compressor hmmmmm
CRV
http://www.tamparacing.com/forums/ho...ompressor.html
Old Oct 22, 2013 | 08:05 AM
kyden's Avatar
how is this not common knowledge already?
del sol p54 or crv. crv cannot be used in conjunction with power steering if i recall.
Old Oct 22, 2013 | 08:09 AM
I need a o2 extension from you.
96 d16y7 car now has a b20 and my o2 is down on the downpipe now rather than in the manifold right near the head like it was on the d16y7
can you help me? i know the connector on the ENGINE harness is a female so the end of my extension harness where it plugs into the enigne harness would need to be a male. and the end of my extension harness where the o2 plugs in needs to be female because my o2 is a male.
20 bucks shipped?
Old Oct 22, 2013 | 08:11 AM
because i do not normally do BSeries crap i normally do h22 swaps.
del sol bracket doesnt work. if i tighten the belt the a/c compressor is gonna have its ears ripped off and i will have to but a compressor.
CRV bracket is what i need because i gotta have more than 2 bolts holding the compressor on. PS isnt a issue because the car is a manual steering car.
Old Oct 22, 2013 | 08:12 AM
ahh p54 may work. I have a p30 one and it is BS
Old Oct 22, 2013 | 12:38 PM
94EG8's Avatar
Seagull Management
P30 isn't a Del Sol AC bracket and wont work. It's from a '99 - '00 Si or JDM B16A with B-series. P54 is the Del Sol bracket.
The easiest thing to do is use a CR-V AC bracket, it's cheaper than the Del Sol version. You can keep PS with this bracket on a B20 (and I think in a B18) it doesn't work on a B16A due to the shorter deck height.
Old Oct 22, 2013 | 01:18 PM
Technical Hero
PM me
k20user
Oct 2, 2010 06:10 PM
wizzards581
Mar 30, 2004 05:55 PM
96BlackHB
Jun 21, 2003 03:14 PM
