Heater STOP Working! Civic 1998 EX
Old Oct 22, 2013 | 06:16 AM
viequense's Avatar
Icon3 Heater STOP Working! Civic 1998 EX
Hi everyone, My heater Stop working last night when I was driving home, everything looks working fine but not hot air coming out the vents.
The blower is working
I check the cable that switch from cold to hot, and the valve is working right
The hoses connected to the valve are hot
It was working right and stop working just like that
I notice when I push the defrost mode the a/c comes one ( green light ) so I puch it to turn it off, but still not hot air coming out.
If this happened to someone and can give me a suggestion will be great! Thanks.
Old Oct 22, 2013 | 10:12 AM
m90polk1's Avatar
Default Re: Heater STOP Working! Civic 1998 EX
Clogged heater core perhaps is the return line hot also ?
Old Oct 22, 2013 | 11:11 AM
DeLSoLRo's Avatar
Check coolant level.
Make sure the temperature **** is on RED lol.
Old Oct 22, 2013 | 01:40 PM
HondaPartsHero's Avatar
Technical Hero
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-fix-your-heater-blowing-cold-takes-forever-warm-up-3007254/
Old Oct 22, 2013 | 02:29 PM
Marvin1985's Avatar
your coolant temp gauge taking forever to warm up? Last time you changed the thermostat?
Old Oct 23, 2013 | 05:26 AM
viequense's Avatar
Yes bove of them are hot
Old Oct 23, 2013 | 05:27 AM
viequense's Avatar
Coolant level is ok, and yes the RED **** is on red.
Old Oct 23, 2013 | 05:32 AM
viequense's Avatar
I will say it take the normal time to heat up, the arrow is always a little under the midlle of the gauge, I change the radiator a year ago, Thermostat not done yet, I was considering that as a reason but the car temp is allways normal.
Old Oct 23, 2013 | 05:39 AM
viequense's Avatar
Originally Posted by HondaPartsHero
Thanks for the Image, I am going to check that right now.
I have one question, when the valve cable is pulled it moves the air mix at the same time or it work apart.?
Old Oct 23, 2013 | 06:24 AM
viequense's Avatar
Ok, thanks a lot to everyone
Following the diagram that HondaPartsHero Post,
I get under the dash and find out tha the tempeture **** was moving the valve cable right but it has 1 white shifter that open and close the vent to control cold or hot air that was not on the guide it was stock on one position, as soon as I fix it, hot air came out of the vents.
Thanks a lot to everyone!
Espiea
Sep 15, 2017 10:18 AM
SPOON_BeIgHtEeNsEe
Honda CR-V & Element
Nov 30, 2010 01:54 PM
TaDLaD
Oct 1, 2009 11:31 AM
GAB2
Nov 19, 2008 04:44 AM
R249
Jan 24, 2003 11:10 AM
