civic eg. no start. no crank.
had a hard time starting the other day. but started. drove around. brought back to the garage. came back the next day. no start. jumped the car. does do anything. you can see the difference is the dash lights when you hit the clutch (clutch switch works). tested battery. battery is good. tried jumping the starter. no luck. bought new starter. still no luck jumping the starter. bench tested starter. good starter. checked all my grounds. made sure nothing was unplugged. ???????????? why does the starter not work... jump box on the car btw.
