2000 DX starting/stalling problems
Old Oct 21, 2013 | 01:44 PM
Sharpen047's Avatar
Default 2000 DX starting/stalling problems
alright guys i have a 2000 DX i just got a couple months ago.I got it with a burnt valve, and many other problems, but, i got it to pass smog.
last friday night i started the car at a friends house and it took 3 or so tries to start, thought it was just a glitch or something and thought nothing of it, drove it to another friends, then started it up when i left there and it was fine. I went to start it saturday morning and it just cranked and wouldnt start.
turns out it had no spark. I have since replaced the coil, ICM and tested the relay via the FSM page that says to power 1 & 2 on the relay and check for continuity between 4 and 5, which it passed.
I can get it to start occasionally and it will idle anywhere from 3 seconds to 10 mins then just die.
ive ruled out fuses and the timing belt because it can idle when it has spark.
i also have new cap, rotor, plugs and wires(NGK plugs and wires).
is there anything else i should check? Any help would be appreciated especially since its my daily that i cant drive. i do have my other car to drive in the mean time.
EDIT: No CEL codes either and battery reads 12v when off and 13.3 when idling
Old Oct 22, 2013 | 02:30 AM
Sharpen047's Avatar
Default Re: 2000 DX starting/stalling problems
Could a bad ignition switch be the problem? Is there a signal wire from the ignition to keep the ecu on? No spark could mean no ecu?
Old Oct 22, 2013 | 10:03 AM
Sharpen047's Avatar
ignition switch tested good. ecu "looks" good.plugs look good, etc going to test harness and get back
Deimus
Dec 5, 2013 05:08 PM
usdmEHboy
12
Jan 17, 2011 04:14 PM
r-6
14
May 9, 2009 05:30 AM
Heeter
Classic Hondas
Apr 21, 2009 12:56 PM
93daintegra
Sep 16, 2008 01:21 PM
