integra rpm problem,car dies, plz help!
Old Oct 19, 2013 | 02:43 PM
cvelazquez's Avatar
Default integra rpm problem,car dies, plz help!
im having trouble with my integra, its a 98 spec integra gsr, stock internals, the car is having idle problem, i did maintenance to the IACV and the problem remains,im buying the valve soon, but my BIG BIG problem is the car when its runnig start to die a lose power and all the sudden power goes back again, after this happen the cars feels just like before, is like is having a miss fire or something because the cars makes explotions,the fuel pressure is alright between 45-50 also when im going full throttle the rpm goes crraaazy,
I replace:
TPS,
CAP,
ROTOR,
WIRES,
CLEANED THE INJECTORS,
CLEANED THE FUEL RAIL,
CHANGE THE IACV GASTEK OR THE LITTLE O-RING
THE CARS WAS PARK LONG TIME ( LIKE 2 MONTH) ALMOST GOT ROB , IM USING A P73 ECU (TYPE R ECU) BUT THE PROBLEM HAPPENED BEFORE WITH THE stock ECU....
any ideas? thanks in advance.....
Old Oct 20, 2013 | 08:53 AM
fcm's Avatar
fcm
Old Fart
Default Re: integra rpm problem,car dies, plz help!
ICM, symptom of a bad ICM is stalling and RPMs on tach going strange. 94
Old Oct 20, 2013 | 11:40 AM
jdmsleeper12's Avatar
Timing? Sparkplug?
Old Oct 22, 2013 | 05:48 AM
cvelazquez's Avatar
timing check, ICM replaced, cars is a lot better now, i was low on gas and the problem remain , when i went to the gas station and put some gas in, the car runs fine again, think is the gas pump or probably sediments on the tank...
cvelazquez
Nov 25, 2013 05:44 AM
BladesTeg
Mar 3, 2011 09:01 AM
repingjdm
May 13, 2010 09:43 PM
DC4_teggy
Jul 10, 2009 02:34 PM
prototype80
Jul 28, 2005 08:55 PM
