1992 Accord - Replacing fuel filter
Old Oct 26, 2002 | 10:42 PM
Orig's Avatar
Default 1992 Accord - Replacing fuel filter
Just want know if I need to de-pressurized my fuel system before replacing my fuel filter? What are the consequences if it's not de-pressurized?
Old Oct 27, 2002 | 01:23 AM
bill-71SS's Avatar
Default Re: 1992 Accord - Replacing fuel filter (Orig)
just open the gas cap
Old Oct 27, 2002 | 04:35 PM
Mr Ben's Avatar
Default Re: 1992 Accord - Replacing fuel filter (bill-71SS)
THere is a service access bolt on the driver side of fuel rail. hold the bigger section w/ a wrench and loosen the smaller bolt. Hold a towel around it to catch the fuel. THen retighten bolt. If you don't do this, you will relieve the pressure anyways, just messier.
Old Oct 27, 2002 | 05:08 PM
4doorH22's Avatar
Default Re: 1992 Accord - Replacing fuel filter (Mr Ben)
Yeah if you depressurize properly you'll get zero spillage when you undo the filter (since the 4G filter input and output are both on the top of the filter). It helps greatly to have an open end wrench big enough to fit around the "nut" of the oil filter. I don't remember if this is 18, 19, or 20mm.
Old Oct 28, 2002 | 05:09 AM
Stew Pidasso's Avatar
When you undo your first fitting just have a rag around the wrench and bolt to catch the fuel. Don't squirt it in your eye...
Dat1BVtecN
May 4, 2006 04:00 PM
zracer240
May 7, 2005 04:32 PM
SexyAzNMami
Nov 19, 2004 12:00 PM
samdawgsol
May 13, 2002 09:40 AM
michaelpr
Mar 16, 2002 12:18 PM
