89 with b18a1 new problem arises
Old Oct 17, 2013 | 09:38 PM
LuckyJDM's Avatar
Default 89 with b18a1 new problem arises
Oks o got my new tranny in and everything blah blah I took the car for a test driver it was running good then when I was at a redlight I started going and the car started bogging and staying stuck at like 2k rpm then I gave it a little more gas and it just felt like i hit vtec but anyways enough joking it happens in every gear it doesnt matter what rpm as soon as I start "cruising" keeping the throttle in the same position its like it fighting itsself then I give it a little gas it will starts backfiring like crazy and then start going normal. It goes through high revs good "racing" but cruising its just terrible its just fighting me. I already have the idea of the distributor, just want to see what HT thinks about this.
Old Oct 17, 2013 | 09:39 PM
LuckyJDM's Avatar
Default Re: 89 with b18a1 new problem arises
I will check everything tomorrow going to bed now just made this post to get some opinions. thanks for everyones help. btw I am throwing no codes "NO CEL"
Old Oct 18, 2013 | 03:06 AM
Freemananana's Avatar
Could be some timing issue. It's got a problem at part throttle, that's weird. No CELs make it hard to really say whats wrong. I'd check the basics out. The little things. Maybe you need a tune up, new plugs, wires, cap ect.
Old Oct 18, 2013 | 09:40 AM
LuckyJDM's Avatar
Timing is good, Ground are good still havent checked the dizzy havent had time going to work in a few.
Old Oct 18, 2013 | 09:57 AM
Are you thinking the distributor is bad or that it is turned too much one way?
Old Oct 18, 2013 | 11:54 AM
LuckyJDM's Avatar
Im thinking rotor is loose, sorry for taking long to reply im at work.
Old Oct 18, 2013 | 12:37 PM
Former User's Avatar
New swap? CEL codes?
Old Oct 18, 2013 | 01:05 PM
LuckyJDM's Avatar
nope swapped it like 6 months ago distributor was replaced about 3 months ago because the ignition module went bad and no CEL all the CEL's I had about 2 months ago were taken care of which was IAT and TPS
Old Oct 19, 2013 | 12:16 AM
LuckyJDM's Avatar
So before I could get around to checking the dizzy I took it around for another test run and perfect like if it never happened but sure enough towards the end of the night after hanging with friends it comes back as im heading home... im just gonna stop being lazy and check the dizzy and check the tps calibration
Old Oct 19, 2013 | 09:21 AM
LuckyJDM's Avatar
Ok well I checked dizzy cap and rotor looks good but the coil looks all rusted out im pointing now towards the dizzy being the problem. The tps is good and calibration is perfect.
Old Oct 19, 2013 | 09:38 AM
LightWeightChamp's Avatar
Start with the dizzy.
are you running obd0 or obd1?
Old Oct 19, 2013 | 01:04 PM
LuckyJDM's Avatar
Obd1 converted the right way.
Old Oct 31, 2013 | 11:20 AM
Ok so I changed the dizzy to a known working dizzy and that didnt fix the problem checked all my grounds etc... Now im going to change the fuel filter and see if that does it. Anyways heres my symptoms for you can give me any more ideas that I may be missing
I drive around ( car runs fine for a while sometimes the whole day without a problem ) and out of no where when Im keeping the gas like at 10-15% throttle and i press on it I feel a bog then I give it a little more gas and it starts sputerring like crazy and making backfires ( i have a 2.5 straight pipe ) so its loud. Then it will jump and go really fast, it will keep doing this until i turn they key off and back on, then sometimes it will be fine for the rest of the day sometimes it will happen again in 5minutes. Its not a consistent thing ( this is the weird thing ).
No need to make a new thread. I'm still thinking and researching myself. You should do the same, maybe bump this thread with an update if anything.
It's not a constant problem so it's harder to troubleshoot. You have to have it acting up and then test things.
Old Nov 1, 2013 | 11:44 AM
LuckyJDM's Avatar
I was looking for this thread and I couldnt find it thats why I made a new one thanks for bumping it ill delete the other one if I can..
EDIT: Ok so I changed the dizzy to a known working dizzy and that didnt fix the problem checked all my grounds etc... Now im going to change the fuel filter and see if that does it. Anyways heres my symptoms for you can give me any more ideas that I may be missing
Old Nov 1, 2013 | 11:46 AM
LuckyJDM's Avatar
Also new update on this, I realized in the morning when I turn my key to let the fuel pump prime I dont hear it like I use to hear it. Im not even sure if its working cause I cant hear it all I even put my ear as close as I could and still nothing. Car runs fine though drove it to work ( im here now ) with no problems. Could it be fuel pump is taking a crap?
Old Nov 1, 2013 | 11:49 AM
It probably wouldn't drive if it was a bad fuel pump.
Old Nov 1, 2013 | 11:51 AM
F22Master's Avatar
Do you have an an adjustable FPR? Sounds like you could be running rich. What do the plugs look like?
Old Nov 1, 2013 | 12:12 PM
LuckyJDM's Avatar
Nope OEM FPR and ok but is it weird that I cant hear my fuel pump priming anymore? I still havent replaced the filter cause been working the last few days but when I get my day off I will and ill give you more updates. Also last night when I was driving home my key shut off trick to fix the problem wasnt working it was the first time that it was becoming constant. Also I realized I know how to tell when its starting to happen. when i come to a stop the idle drops to like 200-300 and I already know when I leave the light its going to start bogging and stuff. Im just trying to find the problems while im driving and what may be causing it
89brokendownEF
Sep 11, 2014 10:14 AM
stdefhatch
Mar 14, 2008 11:17 PM
3k9civic
Sep 15, 2006 08:45 PM
DCnotTHEshoes
Oct 20, 2005 05:19 PM
AllMotor12s
May 24, 2004 12:21 PM
