problem with accelaration
Old Oct 20, 2005 | 01:18 PM
DCnotTHEshoes's Avatar
Default problem with accelaration
im havin a problem with me accelaration. wen i start off, for example on a flat surface, i am accelarating okay in first and i shift at 3-3.5k RPM and then into second and do the same. wen im in third i press the pedal to almost the floor to go faster but it seems like im drivin at the same speed, but as i start to let off the gas it begins to start to kick out and i am accelaratin faster wen lettin the gas out. i thought it was becas my rpms werent up but i also tryed this with my rpms at many dfferent points. this could be the same within 1rst and second gear too but i just dont really feel it as much as 3rd and 4th gear. im srry if this seems a lil confusin to read. help please?
Old Oct 20, 2005 | 01:23 PM
BlackLudeSi's Avatar
Default Re: problem with accelaration (DCnotTHEshoes)
Sounds like your car is bogging? Do you see any smoke at all? When was the last time you did a tune up and misfire can cause what i think your describing. Check you cap and rotor and fuel fitler the usual things to see if anything is off first
Old Oct 20, 2005 | 02:02 PM
djtsmith007's Avatar
Default Re: problem with accelaration (BlackLudeSi)
Dont tell me you have a MSD cap on there do you? If you do, i bet anything one of the ignition wires is gettin snagged by thr rotor inside the cap. Just re-locate the wires out of the way.
Old Oct 20, 2005 | 03:00 PM
Default Re: problem with accelaration (djtsmith007)
there is no smoke and i dont got nethin msd... this happened after i installed my AEM intake and then took it out. so u believe i mite just neeed a tune up? any other suggestions on wat to do...?
Old Oct 20, 2005 | 03:47 PM
v-tecgoswahn's Avatar
i had the same prob for a while too...it ended up being my timing...which lead to misfiring all u need is a tune up
Old Oct 20, 2005 | 03:53 PM
thank you everybody for your help. i really appreciate it. im gonna get a tune up asap.
Old Oct 20, 2005 | 05:19 PM
95lstegman's Avatar
it really really sounds to me like your ignition timing is off or you have bad spark plugs, plug wires, distributor cap or rotor. check those parts.
Winlight
Jun 11, 2007 10:01 PM
jardolei
Aug 18, 2006 06:20 PM
Rickdogg
May 27, 2005 09:54 AM
Beezle
Mar 31, 2005 10:45 AM
tallblondkid
Sep 15, 2004 01:24 PM
