97 Civic blue smoke coming from exhaust ?
Old Oct 15, 2013 | 05:49 PM
barzano724's Avatar
Default 97 Civic blue smoke coming from exhaust ?
I noticed it while I was driving I saw blue smoke coming from the exhaust. Is that because of my straight exhaust and no catalytic converter or is it the head gasket ?
Old Oct 15, 2013 | 06:02 PM
B_Swapped93's Avatar
Default Re: 97 Civic blue smoke coming from exhaust ?
blue-ish smoke is typically oil do a compression test then a wet one post both numbers. Not having a cat would make it more noticeable but I ran my integra with out a cat or resonator or muffler no smoke.....
Old Oct 15, 2013 | 06:04 PM
carlos8's Avatar
Bad head gasket smoke is white. The blue smoke is oil it's making his way to the combustion chamber i.e. Valve seals, piston rings, crack valve guides or even a faulty evap. system. Do a compression and leak down test this is the best way to found your problem.
Bootz
Dec 30, 2018 04:38 PM
EKk9
Jul 27, 2011 03:04 PM
PnoyGS-R
Nov 1, 2010 12:45 PM
LaOXXKIDD
Aug 15, 2009 12:05 PM
RedGSRblingin
May 23, 2002 06:48 PM
