Ebc or powerstop brake upgrade?.
Old Oct 15, 2013 | 01:21 PM
Big Boi B's Avatar
Default Ebc or powerstop brake upgrade?.
I have a 97 hatch been having some stoping problems just got done with a ls swap an the car is running fine only thing is I've had a couple times where I didn't think I was gunna stop fast enough so I've been looking into upgrading my breaks not sure what I should get I was looking at ebc or power stop just wanted to see if anyone has used or liked either or
Old Oct 15, 2013 | 01:53 PM
mechanix619's Avatar
Default Re: Ebc or powerstop break upgrade?.
What tires are you using? Quality tires are a huge part of the equation.
Brembo blanks and Hawk pads have always suited me just fine. I'm making about 440WHP.
I just went through a set of Bridgestone Potenza RE-11 tires.
Old Oct 15, 2013 | 01:54 PM
CX-Adam's Avatar
talks to himself
Community Builder
Community Influencer
Before people start making suggestions, have you done a tune-up on your brakes? (break is the wrong spelling)
Is your pedal firm? Are your tires bald? How are your suspension joints?
Bigger brakes won't necessarily stop you faster. They may just lock up and actually increase the stopping distance.
Read reviews on pads before you buy some. It's a pain in the a'ss to constantly have to wipe down your wheels with dusty pads.
Old Oct 15, 2013 | 03:12 PM
jbpnoman's Avatar
Brembo blank rotors. EBC or Hawk pads are both the winning selection, and they both have low dust "street" pads, as well as high grip "track" pads. As has already been said, though, there's a lot more to your braking system than the pads and rotors - proper tires, suspension, and a brake hydraulic system are even more important than pads and rotors.
Old Oct 15, 2013 | 11:19 PM
Big Boi B's Avatar
I'm using falken 912 there only like 2 months old so still pretty fresh had my brakes replaced around about 6 or 7 months ago
Old Oct 15, 2013 | 11:20 PM
Big Boi B's Avatar
I was looking at these
http://www.buybrakes.com/p-990-ebc-s...brake-kit.aspx
Old Oct 16, 2013 | 01:21 AM
Solster's Avatar
keep in mind that slotted rotors will provide better braking it will also shorten the life of your pads.
this is due to the fact that the point of the slot is to scrap the surface of the pad off each time it passes by. This keep clean pad for the rotor and prevents scorched pad material and dust from reducing the drag/ adhesion (if you use ceramic pads) force on the rotor
http://www.wilwood.com/BrakeKits/Bra...ivic&option=HB
Old Oct 16, 2013 | 05:34 PM
Big Boi B's Avatar
Awesome advice thanks for the help everyone I decided to get brembo blanks an a set of hawk pads
Old Oct 17, 2013 | 02:06 AM
doctorake's Avatar
If you loved me, you'd all sell me your magic cards to me today
Veteran: Coast Guard
Community Builder
Good choice, which hawks?
Old Oct 17, 2013 | 05:05 AM
EsotericImage's Avatar
Retired Moderator
Thats all a myth. Slotted and drilled rotors have less surface area for brake pads to bite. Cheap knock off drilled and slotted rotors crack and the big brands are they only ones to be trusted.
theres a write up on here explaining the reason why solid rotors are better.
Old Oct 17, 2013 | 12:47 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
Default Re: Ebc or powerstop brake upgrade?.
There's also some unfortunate chatter about Brembo rotors moving their mfr-ing to China. No longer made in Italy. So, all the same crap now as the other white box junk. (Discussion begins here.) There is an option out of Brazil (using Brazilian steel), worth considering: VGX. The retailer at that link also sells brake pads that are manufactured in CANADA. Like, whoa. Pretty surprised to see that.
Old Oct 17, 2013 | 12:53 PM
jbpnoman's Avatar
Surprised to see something good coming out of Canada other than the EL, you mean? I mean, Beiber is y'alls fault...
Old Oct 17, 2013 | 12:58 PM
deschlong's Avatar
Loved
Community Favorite
Ugh, don't remind me. Also Kasey Rae something? ... the "Call Me Maybe" girl.
But, yeah: Pretty much I'm surprised when I see anything made anywhere in North America anymore. Or anywhere in the G20, to be honest.
Old Oct 17, 2013 | 01:06 PM
jbpnoman's Avatar
Carly Rae Jepsen. Also Celine Deon, Drake, and Avril Lavigne. All Canada's fault.
At least you gave us Randy Bachman
Old Oct 17, 2013 | 01:09 PM
inda ceja's Avatar
just researched slotted and vented, and unless your tracking or racing your car, braking power is compromised on the streets ( meaning less braking grip ). on the track, they heat up so bad, that you want ventilation ( slotted and drilled ) but on the street, you get better grip on blanks. zinc coating will keep them from rusting, but that's about the gist on rotors. Unless your Dropping big $$$$$ on vented drilled and slotted, personally not worth buying $200 and under rotors that look " pretty ".
I would rather trust grip on the streets to brake in time, and not wreck my car...
buy quality brake pads, and quality blanks.....
Old Oct 17, 2013 | 04:39 PM
Retired Moderator
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/why-blank-rotors-better-than-cross-drilled-slotted-1437513/
heres the one i was refering to
Oscarasimov
Suspension & Brakes
46
Apr 15, 2013 04:56 AM
Shirozu
Acura TSX
Jul 4, 2011 12:08 PM
mityVR6
11
Feb 22, 2003 11:18 AM
Geezer
Jun 10, 2002 04:39 AM
HRC
Aug 2, 2001 07:48 AM
