Motor build
Old Oct 14, 2013 | 07:15 PM
96civicb18a1's Avatar
Default Motor build
Have a 96 civic with a b18a1 block & looks like a b18b1 head. It's non vtec . I kinda wanna make it vtec , but what all would that take ? And what all could I do to it ? I want it a little bit faster but don't wanna spend a **** ton of money help!!
Old Oct 14, 2013 | 07:34 PM
NZXTInerTia's Avatar
Default Re: Motor build
Do your god damned research this has been covered thousands of times.
Old Oct 14, 2013 | 08:19 PM
3rdtimecharmer's Avatar
10 Year Member
+1
search LS-vtec
Old Oct 14, 2013 | 08:34 PM
Originally Posted by 3rdtimecharmer
+1 search LS-vtec
I have the ls swap from a integra I want it to be vtec but heard the ls swap vtec messes stuff up and how much would it be I heard a lot of money ? Would it be cheaper just to get a new intake manifold & add more stuff
Old Oct 14, 2013 | 08:35 PM
I'm new on here & new to Hondas calm your shiy I been researching and get different answers
Old Oct 14, 2013 | 08:59 PM
10 Year Member
if you want to add vtec you have to do a LS-vtec. theres no other way around it.
spending $ on a manifold and other parts for a LS motor just isnt worth it to me.
if you dont have the $ to convert to LS-Vtec correctly or even swap a B16A motor then just leave it and accept your car for what it is..
having a LS swapped 96 civic is faster than most stock civics out there..
if u really want to make ur car faster, save up money and do it right.
Old Oct 14, 2013 | 09:07 PM
doood's Avatar
been there done that
why do people keep thinking going fast for cheap is a good idea?
Old Oct 14, 2013 | 09:41 PM
kaycee_00's Avatar
Because of youtube.
Old Oct 15, 2013 | 06:13 AM
I don't . I don't mean cheap cheap . What's a good vtec ls conversion? & I found golden eagle for about 300 bucks but what else would I need
Old Oct 15, 2013 | 06:19 AM
doood's Avatar
you havent read a single reply in this thread have you?
Old Oct 15, 2013 | 06:43 AM
1ls/vtec's Avatar
Golden Eagle LSV conversion kit, ARP head studs/rod bolts, B16 or GSR head, chipped p28 or p30 ecu. I highly recommend ARP rod bolts due to running higher rpm's and the rods are usually the first thing to go.
Old Oct 15, 2013 | 07:17 AM
kaycee_00's Avatar
And a new timing belt if you decide to use the 19 tooth water pump.
Old Oct 15, 2013 | 07:53 AM
If I didn't do the ls vtec what would you recommend me to do to the motor ?
Old Oct 15, 2013 | 09:16 AM
kaycee_00's Avatar
Depends on how much your trying to spend to go that little bit faster.
Old Oct 15, 2013 | 10:03 AM
Not to much just a few hundred
Old Oct 15, 2013 | 11:50 AM
10 Year Member
i think your just waiting for someone to tell u what u want to hear because everyone has given u options and advice and what not and u just ignore it. then come up with a new question.
you only want to spend a few hundred bucks and expect to be that much "faster" good luck man.
u cant do much with a few hundred bucks to an ls. or any motor for that matter to make respectable power. yah maybe an intake and a axleback muffler? but then what, you just turned your car into another fart can ricer.
just save up your money and do it right.
Old Oct 15, 2013 | 11:56 AM
kaycee_00's Avatar
Just buy bolt ons. Everything else is going to be way more than you want to spend.
Old Oct 15, 2013 | 07:24 PM
What kind of bolt ons
Old Oct 15, 2013 | 07:32 PM
doood's Avatar
the cheapest ones you can find because you're just wasting your money anyway
Old Oct 17, 2013 | 08:40 AM
What do you think I should so to it ? Forget about the cheap upgrades what is your opinion on what I should do to the motor
jeremy moses
Oct 1, 2007 05:08 AM
RickyBizee
Jun 14, 2005 10:32 AM
mugenspoongsr
May 27, 2005 08:21 PM
Spoogen_1
76
Jan 7, 2005 01:26 PM
coombs
Dec 10, 2003 02:45 PM
