Ls V-tec question
Old Jun 13, 2005 | 06:35 PM
RickyBizee's Avatar
Default Ls V-tec question
OK i don't know much about this stuff so try to work with me. I just bought an Integ LS, i want to do a ls v-tec, will any v-tec head fit or do i have to have a certain one? and what else will i need to do the swap?
Old Jun 13, 2005 | 06:38 PM
Yambor's Avatar
Default Re: Ls V-tec question (RickyBizee)
search...please,
Old Jun 13, 2005 | 06:52 PM
rdblckSV650S's Avatar
Default Re: Ls V-tec question (JH4DC4-2GSR)
please do a search. There's alot more to it then just getting a head and a few parts. You need to learn every aspect of the LS bottom end and learn why lsvtec can be both powerful, and unreliable.
Old Jun 13, 2005 | 06:57 PM
brad98_teg's Avatar
VTEC not V-tech
Old Jun 13, 2005 | 07:03 PM
RickyBizee's Avatar
Default Re: Ls V-tec question (brad98_teg)
ok sorry just signed up today im doing a search now.
I put v-tec not v-tech
Old Jun 13, 2005 | 07:31 PM
Racermech's Avatar
no it is VTEC not V-Tec or VTECH VTAK or anything like that. It is Vtec....plain and simple
Old Jun 13, 2005 | 07:37 PM
RickyBizee's Avatar
Default Re: Ls V-tec question (Racermech)
ok sorry, I'm use to seeing the - in the rsx motor the i-vtec OKI DOKI!
Old Jun 13, 2005 | 09:44 PM
Catscan's Avatar
Banned
That was a little harsh. Then again I bet you just wish you had V-tech.
Good luck with finding info on the conversion. I originally planned to do that but after researching it the gains weren't worth the price. I decided to save up for an h22 swap, but another choice for you is to replace the springs and retainers ($300 Aprox. + labor) and bump up the rev limiter. I pushed mine to 8200, but after about 7600 I run out of power. Im not sure if cams would help that, but I would assume so. Also, dont forget that ls engines love boost, you could put a turbo kit in for around $2000, if your engine is still good.
Old Jun 14, 2005 | 10:22 AM
RickyBizee's Avatar
Default Re: Ls V-tec question (Kaltes Feuer)
yeah after researching ...the gaines weren't worth it....so now i'm looking up turbo, and i've been looking on ebay for parts and i just realized that if you order all the parts seperate you can build your own turbo for about 1200 dollars thats including everything waste gate, hoses pipes, turbo , manifold, intercooler, blow off valves, fmu, etc. and even a map sensor by pass valve but i have seen full turbo kits for like 1500 so i wonder if you would just rather spend 300 more dollars and save your self mucho searching. only you'd still have to get a mapsensor bypass and fmu....hmmm
Old Jun 14, 2005 | 10:32 AM
kevin85193's Avatar
Seriously, do you people look at this forum at all. There is about 50 posts about same subject on the main integra page.
juandaman
Jan 22, 2009 06:32 AM
95_red_dc
May 24, 2006 01:02 PM
chris3k
Feb 2, 2006 07:29 PM
RSNTEKRA
Oct 3, 2005 10:58 AM
WiLLMaTiX
Apr 12, 2004 03:59 PM
