Electrical Expert needed NO START 100% stock INTEGRA
Old Oct 14, 2013 | 06:06 PM
cb169's Avatar
Default Electrical Expert needed NO START 100% stock INTEGRA
HI have a 2001 integra all stock and untampered with, no start at TIMES and when it does not start it dumps fuel because the injectors are wide open and has been confirmed with an injector noid light, once it starts car runs fine after I rev it ah bit and clear out the plugs, noid light is dim when it starts fine and very bright when it dont start and high scent of fuel
Old Oct 14, 2013 | 06:34 PM
sirtef9's Avatar
Default Re: Electrical Expert needed NO START 100% stock INTEGRA
When does it not start, cold or hot?
Old Oct 14, 2013 | 07:07 PM
cb169's Avatar
happens randomly when its cold or hot
Old Oct 14, 2013 | 11:26 PM
9d2blkDA's Avatar
what does it sound like when you try to start it ?
Old Oct 15, 2013 | 07:05 AM
fcm's Avatar
fcm
Old Fart
The ECU/ECM controls injector pulse, I would try another ECU/ECM, it sounds like yours is defective. 94
Old Oct 15, 2013 | 11:50 AM
cb169's Avatar
cranks normal
Old Oct 15, 2013 | 11:52 AM
cb169's Avatar
was thinking the same but has an immobilizer and don't have a jumper harness at the time and its an automatic, was also thinking maybe a bad TPS cause I have never seen a ECU go bad that has not been tampered with but anything is possible
Old Oct 15, 2013 | 11:59 AM
fcm's Avatar
fcm
Old Fart
We see bad ECUs all the time, I have never seen a bad TPS prevent engine starting, running properly yes, starting no.
The only thing that would keep the injectors open is the ECU, or a short, [to ground] on the ECU injector control leads. 94
Old Oct 15, 2013 | 12:35 PM
cb169's Avatar
Reason why I suggest tps cause when u open the throttle or turn the tps the noid light goes bright, if I pinch the fuel inline it starts right up, found another ECU in my shop but it wont start cause of the immobilizer, any way of bypassing the immobilizer?
E Swift
Jul 10, 2019 03:46 PM
TEG_UR_IT
Oct 20, 2012 11:11 AM
ezcape
Apr 5, 2011 06:23 PM
aznjay510
Aug 27, 2009 02:54 PM
