96 acura interior lights not working
Old Oct 13, 2013 | 08:44 PM
96 acura's Avatar
Default 96 acura interior lights not working
96 acura interior lights not working but the dash lights and radio and clock and fuze is good and all blubs are good and cant fine and broken wires, its going to be winter soon i need help thanks
Old Oct 14, 2013 | 11:41 AM
fcm's Avatar
fcm
Old Fart
Default Re: 96 acura interior lights not working
Do you mean the cluster lights/illumination? 94
Old Oct 14, 2013 | 01:13 PM
96 acura's Avatar
no dome lights
Old Oct 14, 2013 | 01:30 PM
fcm's Avatar
fcm
Old Fart
So fuse #3 -7.5A, [hot at all times] in under dash fuse box is good?
Does the trunk/hatch kight work?
Does the door "open" indicator in the cluster work? 94
Old Oct 14, 2013 | 01:46 PM
96 acura's Avatar
the fuze is good and the trunk one dose work
Old Oct 14, 2013 | 01:49 PM
96 acura's Avatar
the cluster and radio and clock all work
Old Oct 15, 2013 | 06:45 AM
fcm's Avatar
fcm
Old Fart
The trunk and dome light are on the same fuse but the leads run off diff. plugs on the fuse box.
If you have not already, check the dome light bulb and test for power a the dome light, [white/red lead].
The light green/red lead is the ground from the door pin switches, should test as a ground when a door is open.
If you are not getting power/ground up at the dome light, check and make sure the dome light harness is plugged in, the plug will be high up under the dash by drivers A pillar. 94
Old Oct 15, 2013 | 10:17 AM
96 acura's Avatar
ok i check again
Old Oct 15, 2013 | 01:08 PM
96 acura's Avatar
no power and grounds are good but still no power and i put new blubs in can you get a diagram
Old Oct 16, 2013 | 08:50 AM
tamboo's Avatar
10 Year Member
http://107.imagebam.com/download/_P3...6/page1279.jpg
grab the manual:
http://www.hondahookup.com/forums/do...?do=file&id=45
Old Oct 17, 2013 | 04:33 PM
96 acura's Avatar
nothing im guessing it must be a relay
Old Oct 17, 2013 | 04:48 PM
fcm's Avatar
fcm
Old Fart
Dome light is not on a relay.
Did you confirm dome light harness is properly plugged in? 94
Old Oct 17, 2013 | 08:23 PM
96 acura's Avatar
yes
Old Oct 18, 2013 | 05:47 AM
96 acura's Avatar
i pulled everything off, run all wires and nothing n no brokein ones
Old Oct 18, 2013 | 07:11 AM
fcm's Avatar
fcm
Old Fart
Then you will need to fallow the power lead for the dome light, [white/red] all the way back to the fuse box to find the "open", testing for power along the way.
As I said, the power for the dome and trunk/hatch lights are off the same fuse, but exit the fuse box off two different plugs, pin #11 plug C440 for dome and pin #6 plug C504 for trunk/hatch. 94
Old Oct 18, 2013 | 07:45 AM
96 acura's Avatar
ok im going back under ill run the wires again
Old Oct 18, 2013 | 06:39 PM
96 acura's Avatar
nothing its like the power just stops in the wire or somthing crazy like that
Old Oct 19, 2013 | 08:56 AM
96 acura's Avatar
i got it work and the diagram is crap!!!! i pulled every wire from the fuse box and it made something work yeahhhhhhhhhhh
Old Oct 19, 2013 | 11:24 AM
fcm's Avatar
fcm
Old Fart
Then a plug to the fuse box was not plugged in properly so a poor connection or there was corroded pins.
Either way it's fixed now. 94
zenmark84
Sep 15, 2018 05:57 AM
got00rice
Dec 5, 2009 01:21 PM
reefranger
Oct 2, 2005 02:54 PM
urgonnalearn2
Aug 3, 2004 06:45 AM
