00 ex idle problem
Old Oct 13, 2013 | 05:33 PM
Ej8_KiD's Avatar
Default 00 ex idle problem
I just recently installed a new engine harness , tucked harness ( new wires , pins etc) started the car and the idle is really rough and at around 400 almost to the point of shutting down. now i calibrated the tps thinking it was that but i could only get 4.40v at WOT. i had some issues with the throttle body sticking once too , any ideas? distributor is brand new also.
Old Oct 13, 2013 | 05:50 PM
jbpnoman's Avatar
Default Re: 00 ex idle problem
Did you play with the throttle rotor set screw at all? Have you tried adjusting idle? There's a how-to in the FAQ's sticky.
Old Oct 13, 2013 | 06:09 PM
Former User's Avatar
What's the WOT voltage if you adjust the closed throttle voltage to 0.5V?
CEL codes?
Old Oct 13, 2013 | 06:27 PM
Ej8_KiD's Avatar
CEL codes?
no cel codes , closed is at .50v and WOT is 4.40v
Old Oct 13, 2013 | 06:29 PM
What's the input TPS voltage?
Old Oct 13, 2013 | 06:32 PM
Ej8_KiD's Avatar
i didnt get around to test that
Old Oct 14, 2013 | 03:18 PM
Ej8_KiD's Avatar
4.98 volts
Gingerbread
Nov 29, 2017 05:12 PM
zero-one
Feb 14, 2008 04:20 PM
924doorEG
Nov 19, 2007 08:15 AM
Prevail
Feb 12, 2005 06:02 PM
kaj
Sep 1, 2004 04:37 PM
