2001 integra ls: car wont start
Old Oct 12, 2013 | 12:17 PM
ohhsoogood's Avatar
Default 2001 integra ls: car wont start
So my car died out on me in the middle of the street yesterday. Check the engine and there is no sparks. Change the spark plugs and wires, change the dizzy, and now still car wont start. Could it be the ecu? Please help.
Old Oct 12, 2013 | 12:49 PM
kaycee_00's Avatar
Default Re: 2001 integra ls: car wont start
Is there a solid check engine light on? Was the car acting up prior to it shutting off or did it just suddenly die.
Old Oct 12, 2013 | 01:13 PM
ohhsoogood's Avatar
This is the first time I have problem with this car since I first own it. It never gave me any issues. CEL came on and showed a code 8. Had that fixed and still not starting.
Old Oct 12, 2013 | 01:23 PM
kaycee_00's Avatar
Fuel pumps still priming when you turn the key? And you made sure to put the plugs back in the correct order right?
Old Oct 12, 2013 | 05:04 PM
ohhsoogood's Avatar
Yup I put everything back in order and now theres no spark.
Old Oct 12, 2013 | 05:16 PM
B_Swapped93's Avatar
will it crank tho ? or nothing
Old Oct 12, 2013 | 05:18 PM
kaycee_00's Avatar
On the off chance it happened, did you check to see if the timing belt broke? The only other thing I can think of is the new distributor you got is also bad.
Old Oct 13, 2013 | 04:17 AM
tamboo's Avatar
10 Year Member
tested your sparkplug wires?
Pworld925
Dec 31, 2011 12:24 PM
sLoWrAcEr
Jan 16, 2010 08:38 PM
93h22a1vtec
Jun 3, 2006 07:47 AM
incognitoracerr
May 6, 2003 03:07 PM
